Meth injection question
Old Aug 9, 2007 | 05:33 AM
dudical26's Avatar
Originally Posted by SlowCar
me
plots of afr, b4/after, boost...
https://www.evolutionm.net/forums/sh...3&postcount=75
I forgot that you were running a "simple" on/off system. Any plans to run FIA2 in the future?
Also, can you feel when the meth starts spraying?
One of the criticisms I have heard with on/off systems is that in higher gears when you are not really on it but just passing a car on the highway, you can feel it kind of bog the car when it starts to spray. What is your trigger point?
Old Aug 9, 2007 | 08:25 AM
SlowCar's Avatar
i have the FiA2/hsv from my VIII...just kind of lazy to tear up this setup, might do it later if i go bigger turbo.
the only time i know the meth is injection is when i see the LED light bars on DDS3 gauge light up, i dont notice any transistion at all
i trigger @10psig - only thing i notice on high gear/partial throttle is sometimes, popping noise from combustion in the exhaust die to rich conditions
Old Aug 9, 2007 | 08:31 AM
dudical26's Avatar
Got it, I have my system turn on at 3psi so that I can run aggressive tuning during spool up, I dont know how well it would work to start spraying at 3psi with an on/off system.
Old Aug 9, 2007 | 08:34 AM
zsevo's Avatar
what is the best failsafe and what do you think is the best overall kit? the aquamist
Old Aug 9, 2007 | 08:44 AM
SlowCar's Avatar
i'm spraying 1.0mm X 2 atomizing nozzle...~16GPH on a Hago equivalent nozzle...the twin 5 quart tanks will be empty real quick at so early trigger
Old Aug 9, 2007 | 08:50 AM
SlowCar's Avatar
imo, there are ONLY 2 standalone failsafes that work, the Aquamist DDS3 and the Zeitronix ZT-2.
The DDS3 detects actual disruption/loss of flow of injectant, Zeitronix detects the after effects, high egt/afr.
Each component in the aquamist system is designed/spec'd for water/methanol injection, the quality/performance of the system is unmatched.
Old Aug 9, 2007 | 09:52 AM
zsevo's Avatar
Thanks i'm definetely leaning toward the aquamist system seems to be worth the extra cash
Old Aug 9, 2007 | 10:00 AM
dudical26's Avatar
Abner - are you using one of the in line restricotrs?
If so which one and where did you place it?
I am planning to switch out my .7mm nozzles for 1.0mm nozzles.
Old Aug 9, 2007 | 10:07 AM
xiaoni420's Avatar
There is absolutely no question about it, the Aquamist kits are the Best.
Old Aug 9, 2007 | 10:39 AM
SlowCar's Avatar
no restrictors, twin 1.0mm in full force
Old Aug 9, 2007 | 10:43 AM
xiaoni420's Avatar
There is absolutely no shortage of methanol in our twin 1mm nozzle setup
Old Aug 9, 2007 | 10:45 AM
SlowCar's Avatar
lol! going fast cost methanol
Old Aug 9, 2007 | 10:47 AM
dudical26's Avatar
Does not using the restrictor matter?
Richard suggested I use one but to be honest I dont really understand what it does?
Old Aug 9, 2007 | 10:54 AM
SlowCar's Avatar
i guess w/o the restrictor, you will just flow the max flow rate of the atomizing nozzle ?
voltexct9a
17
Sep 5, 2012 07:41 AM
E85evo8
E85 / Ethanol
Nov 2, 2009 05:15 PM
snafufx
31
Apr 11, 2009 09:02 AM
Zoxygen
20
Sep 7, 2007 08:50 PM
fenriq007
19
Apr 6, 2007 08:14 AM
