my engine blew....any thoughts and help?
Old Aug 20, 2007 | 07:26 PM
  #106
EVOclub4's Avatar
Originally Posted by SlowCar
there is an inscription on the hago nozzle......MW15...M15...M10 etc......you should be able to see it.
ok i see it...the top of the number has been "erased" but im guess it's a HAGO MW7
  #107
SlowCar's Avatar
WOW!
Old Aug 20, 2007 | 07:28 PM
  #108
gunzo's Avatar
Originally Posted by lemmonhead
here ya go from the meth injection section in advance.
I also found PHd research work done. Its finding are;
Our calculations indicate that methanol adsorbs chemically by donating electron charge from the methanol oxygen to the surface aluminum. We find that the surface atomic structure changes upon adsorption, most notably the spacing between the outermost Al and O layers changes from 0.11 Angstrom to 0.33 Angstrom.
Water and oxygen in sufficient concentrations inhibited attack, probably by virtue of the protective aluminum oxide that is maintained in their presence.
Also from another research finding,
methanol exhibits both hydrophobic and hydrophilic character. It has an —OH radical which can bond readily with the surrounding water molecules. It also has a methyl radical which cannot bond and is hydrophobic. Both headgroups are sufficiently simple in structure to be interpretable in a diffraction experiment at the atomic level.
so the final conclusion is, Adding 100% methonal will cause corrosive problems on aluminum, Adding water offsets this corrosive problem. methonal is hyrophilic.
As long as you use fresh methonal/water mix every time you start the car, dont lean it out to much because of the extra Oxygen from hyrophilic nature of meth. And there is no left over methonal left inside the chamber by running the engine without using meth for awhile you will probably will not experience problems.
this I guess can get expensive having to toss away tons of unused methonal.
here are a few of the links
http://www.isis.rl.ac.uk/isis2001/hi...ydrophobic.htm
http://pubs.acs.org/cgi-bin/abstract...ef950164e.html
http://en.wikipedia.org/wiki/Methanol
Offline
Lemmonhead, what you posted is correct .. but if you look at ALL the references .. they talk about methanol IN TANK .. not sprayed separately .. it is hygroscopic and that causes problems in the fuel lines ..
As for the corrosion issues .. methanol corrodes aluminium if it is IMMERSED over a period of time.. what you do when you spray methanol is like minimal time in the intake (unless there's wetting or the nozzles leak) and then its burnt / vaporised..
In fact if 100% methanol absorbs water and is sprayed into the engine.. it will not cause a blockage in the nozzle.. water actually helps in delaying detonation..
Check out This website for more information regarding what you need to know about 'water' injection
I've been using mixed water/alky for more than 4 years and the car is tracked frequently ... 20-30 mins of high boost high load on the track with no issues.. And the only time I had to rebuild the engine was when the oil cooler hose broke loose on the track and the engine seized ..
Old Aug 20, 2007 | 07:30 PM
  #109
Aby@MIL.SPEC's Avatar
if you're refering to when the motor blew, it happened at somewhere between 3500-4000rpm in 4th gear. once it hit 21 psi (29 full boost) the motor went...
if you're refering to the engine's life, 7200rpm....
yeah, i was refering to engine life.......the reason why i asked, SOME people who have taken their stock rod/rod bolted engines past 8,300 have experienced big end failures / spun rod bearing....but this is 95% of the time in cylinder #1.
..........interesting thing is, based on the dyno chart you have posted in another thread, it looks as if they ran the engine to ~7,500 what is the rpm interval of the dyno chart used?
btw, who does your nails
Old Aug 20, 2007 | 07:32 PM
  #110
EVOclub4's Avatar
ok well.....im gonna continue to work on the car now instead of the computer. ill take more photos of my disassembly along the way.
Old Aug 20, 2007 | 07:34 PM
  #111
Jeff_Jeske's Avatar
-the motor "went" before i hit full boost at approx 1.5bar ~ 21psi.
-it was in 4th gear rolling around 40mph (3100-3200 rpm)
Well I got to tell you I would be afraid of loading up the engine like that too.
4th gear at 3100 WOT going up hill........
  #112
EVOclub4's Avatar
hahaha....shiet bro?! my nails ....jus playing man....ill check up on that dyno chart......and work on my car...so ill post later on tonite
Old Aug 20, 2007 | 07:40 PM
  #113
evilempire76's Avatar
I would think the M7 is to small for the amount of max boost you were running, but your engine didn't fail at that level of boost so who knows. I would still think that you would need an M15 to run that much boost with an FP Green.
Old Aug 20, 2007 | 07:49 PM
  #114
AlohaEvo's Avatar
.5 starting at 1.5
Old Aug 20, 2007 | 07:58 PM
  #115
DynoFlash's Avatar
Originally Posted by keevo54
Dont try to say that wasnt a direct stab at AMS
No - you are reading into my words
I have stated previously in this thread that I have no basis to question the tuning on the OP's car and that the work I have seen from AMS has only been very good. To me there is no reason to question the quality and competance of the tuning provided and PLEASE do not try and put words in my mouth.
My statement was directed at my former customer who had TWO (2) tunes from me and who never had any engine failure - but somehow had a SEL which he attributes to my tune and also says that he was unable to reach me by phone.
I have suggested that my former customer contact me to discuss his issue and a possible resolution - however - it seems clear that he has no intention to contact me or resolve his problem.
I was trying to put his problem in perspective.
He claims that my tuning is dangerous yet out of the thousands of cars I have tuned there is no incidence of engine failures related to my tuning.
Al
Old Aug 20, 2007 | 08:03 PM
  #116
DynoFlash's Avatar
On the SMC kit the M7 is a very small spray of alcohol. The idea with the nozzel is to select the smallest one that will do the job. The reason for this is for several purposes
# 1 - You want to keep the car as much as possible a EFI car with the precision of a fuel injected fuel delivery. Progressive boost referenced systems are very crude and have poor resolution, especially as in the case of the OP where the MAX was set to 20 psi.
#2 - With a small nozzel in the event of a failure you have a better chance to survive until you notice the problem as the alcohol is a smaller proportion of your total fuel and if you tune on the rich side there may be enough gas to keep you running.
#3 - With a smaller nozzel your alcohol suply lasts longer as you are spraying less
Therefore, the way to properly size an alcohol nozzel is to use the smallest nozzel that will supress detonation for the given application. You move up in jet size until there is enough alcohol to achive the desired octane and charge temp reduction needed.
Old Aug 20, 2007 | 08:33 PM
  #117
TTP Engineering's Avatar
M7 can be sufficient with proper pressure and spray on and full on settings.
It has proven to be sufficient on GT35R Evos we have tuned to 32psi.
Old Aug 20, 2007 | 08:45 PM
  #118
EVO8TOR's Avatar
Carlo, I think the number was scratched by the wrench while torquing it down...I think.
Old Aug 20, 2007 | 09:34 PM
  #119
DynoFlash's Avatar
Of course the sufficency is realtive to many individual considerations
Every car is different
A GT35R can actually work better than a green of stock turbo with pump and alchy as there is less back pressure and better cylinder evacuation.
Which nozzel to pick really comes down to how an individual car is reacting.
Old Aug 20, 2007 | 10:09 PM
  #120
lemmonhead's Avatar
ya that is what i thought, no comment cause I called you out!
I thought about responding, however you are your own worst enemy and you damage yourself the worst in your own posts. You need no assistance.
You have ZERO actual experience with methanol injection. End of story.
