Evolution 1 (yes. ONE!) drivetrain question.
Old Oct 1, 2007 | 09:25 PM
  #46
94AWDcoupe's Avatar
On the tranny itself. The raised rectangular plate on the top of bell housing.
Old Oct 2, 2007 | 09:48 PM
  #47
randedge's Avatar
WQWE
So, what fluids should I use? I've google searched, but can't find info on Galant VR4.
Old Oct 2, 2007 | 09:51 PM
  #48
xspsi4's Avatar
My evo 1 has front center and rear lsd but it also has a group n rally trans so I don't think it had one from the factory my friends evo 3 does have a front lsd. There is an easy way to check pull out the drivers rhs axle and if it measures 15 mm longer than a standard 1g dsm one then it is lsd.
Old Oct 2, 2007 | 11:38 PM
  #49
RaNGVR-4's Avatar
Yep thats another way to check if you have a front Viscous LSD. just like my old galant had in its RS tranny
AWD94 you are missing a tranny code in that list, WQEK is off a late galant vr4-RS with the front viscous lsd, 3.909 final and short gearing.
As for your evo 1 Rand: it does not have a torsen rear, never EVER did mitsu put torsen diffs in the rear of evos. I would use a high quality differential fluid though, like redline, or the factory mitsu diaqueen gear oil (not sure which one they spec for the rear end, theres a few different types out there.)
Old Oct 3, 2007 | 03:43 AM
  #50
94AWDcoupe's Avatar
WQWE is evo 1 GSR with LSD
Old Oct 3, 2007 | 06:42 PM
  #51
randedge's Avatar
Hi,
I plan to sign up at the lancer register .com (net.. something)
Seems to be more first 2nd and III evo information there.
BUT, I gotta change drivetrain fluids soon before I could do that.
So, this has gotta sound really dumb, but bear with me; I haven't a shop manual, and my owners manual is all in Japanese.
What specific fluids do I use in Tranny? Transfer Case? Rear Diff?
What kind? viscosities? Andy brand recommendations?
The last car I owned is an MR2, one transaxle requiring run of the mill transmission fluid to change the driveline fluid. (I remember using MT90)
Also, any tips on changing the coolant/antifreeze?
Oh, and thanks for 94awdcoupe. That settles it! I do have front lsd! yah!
Old Oct 3, 2007 | 09:31 PM
  #52
xspsi4's Avatar
bg syncroshift 2 in the trans redline light weight shock proof in the t-case.
Old Oct 3, 2007 | 09:32 PM
  #53
RaNGVR-4's Avatar
The front just use any tranny fluid you like, redline MT90 is a good fluid, I used to use it in my galant vr4. for the transfer case and rear diff, I always used redline heavy duty shockproof, but since your in canada, that stuff might be too thick for your colder temps up there. take a look at either the 75w90 or 80w140 gear oil's, they would work well for the x-fer case and rear diff. Or you coulkd always use factory fluids. expensive, but they work too.
Old Oct 6, 2007 | 12:02 PM
  #54
randedge's Avatar
Capacities?
I know I sound like a really really stupid kid... but you have to put this in perspective: First RHD car that didn't come with an owners manual that I could read.
Old Oct 6, 2007 | 12:24 PM
  #55
randedge's Avatar
Nevermind, I've found DSM website that lists these. Hopefully, they're all the same.
So MT90 is fine on a front transaxle with LSD?
Old Oct 6, 2007 | 12:41 PM
  #56
randedge's Avatar
Another question: Where does the intercooler sprayer get it's liquid from?
I don't see an extra tank for that...
Old Oct 6, 2007 | 04:12 PM
  #57
gtpumps's Avatar
If you want advice on early EVO's we have them all in Australia www.evolutionoz.net
Old Oct 6, 2007 | 04:35 PM
  #58
WADADLIG_OZ's Avatar
The water for the intercooler sprayer comes from the wiper fluid bottle.
I joined up with Evo OZ a while back.
I need to check it back out.
WADAD
Old Oct 6, 2007 | 05:23 PM
  #59
Saotome9's Avatar
are you sure its a 1?
16 turbo
Apr 5, 2016 10:31 AM
Ralliartize It
Jan 6, 2012 11:43 AM
o-townFLA
52
Oct 11, 2010 11:22 PM
bad driver
Asian Forum
30
Aug 30, 2007 05:50 PM
