Stock Differentals.
Old Sep 13, 2007 | 07:45 AM
FloopyDisk's Avatar
Stock Differentals.
I just did a search, way too many posts and not sure what exact wording to look for. So I apologize if this has been posted before.
Anyways, my question is, what is the stock differental types? LSD? Visicous (Spelling?)? Open? 1.0/1.5/2? Front and rear please.
Thanks!
Old Sep 13, 2007 | 07:54 AM
TeStUdO's Avatar
Your stock differential on your '03 is an open diff.
Old Sep 13, 2007 | 08:02 AM
FloopyDisk's Avatar
Front and rear?
Old Sep 13, 2007 | 08:08 AM
Tom-05-MR's Avatar
2003 USDM Evos had an open diff up front, a viscous coupling in the middle, and a 1.5-way clutch-type limited slip in the back. 2004 models were the same, except that RS's received a geared torque-sensitive differential in the front. All 2005+ USDM Evos have the front geared torque-sensitive differential and the clutch-type rear, but instead of the viscous center they have ACD, which is an electronically controlled clutch center differential.
Old Sep 13, 2007 | 08:41 AM
DaWorstPlaya's Avatar
2003 EVOs have the following:
Front: Open
Center: Viscous
Rear: Clutch type LSD
2004 EVOs are the same as 03 except the RS model which has a helical front LSD
2005 + EVOs have the following:
Front: Helical LSD
Center: Hydrolic clutch type controlled by the ACD
Old Sep 13, 2007 | 08:50 AM
FloopyDisk's Avatar
We should probably sticky this information, thanks guys.
Any recomended diff setups?
Old Sep 13, 2007 | 09:01 AM
TeStUdO's Avatar
You can never go wrong with a RalliArt or a Quaife on the front open diff.
Old Sep 13, 2007 | 12:22 PM
FloopyDisk's Avatar
Quick question.
What's the best type of diff to use with AWD? 2 produces a lot of understeer, so maybe 1.5?
Old Sep 13, 2007 | 06:10 PM
FloopyDisk's Avatar
Class bump.
Old Sep 14, 2007 | 08:13 AM
FloopyDisk's Avatar
ok, last bump.
Old Sep 26, 2007 | 12:39 PM
meckert's Avatar
Ok, Info here is great..But on the open differential in the frt-- I translate this to mean there is really only one drive wheel in the frt? (likely the rt)? Any one care to confirm. I am questioning this as this wouldn't be AWD by definition..Just checking and it may be a symantic issue all around..Who wants to jump in here?
Old Sep 26, 2007 | 12:47 PM
rcheung's Avatar
Yes it does three wheel with an open differential but only when traction is needed. If you were to put the car on a lift and drive, all 4 wheels would spin.
Old Sep 26, 2007 | 03:41 PM
meckert's Avatar
Figured---thx for the confirmation..
Old Sep 26, 2007 | 10:38 PM
barneyb's Avatar
With an open front differential three wheel drive would occur only when one front tire had no traction - an unlikely occurrence on dry pavement.
PHILLY EVO
Apr 6, 2015 04:18 PM
cantgetenough
Feb 12, 2013 10:29 AM
marvix
Aug 7, 2012 07:17 PM
zikizira
17
Apr 9, 2010 04:25 PM
donnie25
Feb 5, 2010 09:25 AM
