BR3065+pumpgas+25psi??
Old Sep 25, 2007 | 07:37 PM
joel(PA)'s Avatar
Originally Posted by vwjeff
Yep.
Buschur parts, and self tuned. I have Cosworth 272's, I use to have only a 280 HKS exhaust cam... I was just waiting for a good cam set, and Dave was all over these. So I figured give it to me . Buschur has it all figured out as to what works best and what doesnt.
No I have no alky/meth injection. Its either 94 pump, or C16. Lastnight it was pump, as I had no real reson for the C16.
Granet the c6 was 100% stock, and dyno'ed 440whp, the week before... Brake Boost FTW!
nice setup. i am kind of regretting not getting the 35 now. im running the same setup as you except i have 3065. where do you see full boost?
Old Sep 25, 2007 | 08:12 PM
vwjeff's Avatar
Yesterday on the way home from the track on my pump gas flash I was seeing full boost at around 4500 to 4700rpm if I remember right. If anyone desides to rise the BS flag on that... I will get video.
Nothing wrong with the 3065 man, JaRRod showed that to be a great turbo at the track
You have the best parts money can buy for your car, and I an sure you will be more than happy for awhile anyways.... then you'll wanna go bigger like me
Old Sep 25, 2007 | 08:21 PM
dxbevo9's Avatar
should i go 35 or 3065?? at 25~26 psi??
Old Sep 25, 2007 | 09:46 PM
Nissan2Evo's Avatar
3065...from what I've gathered at that psi it would spool slightly sooner than the 35r and make roughly the same power.....after 30 psi the 35r flashes its goods. Either way you'll have one hell of a beast with either one. Please post your dynos,impressions,times,etc with whatever choice you do go with..I'm curious how well the S1's will perform with these larger turbos. I have always looked at it as the smaller cam profile helping the turbo spool faster by providing a fatter mid range powerband. Then once the cam starts losing it's edge big brother turbo picks up the slack for the top end. Good luck with whatever route you choose
Old Sep 26, 2007 | 03:27 AM
RSGuy's Avatar
I have yet to see any dyno charts showing a noticeable improvement in spool with a 3065 over a 35R. I really hope to be proved wrong bc if it does indeed spool noticeably faster, then the 3065 would be a great choice for me.
Old Sep 26, 2007 | 10:28 AM
dxbevo9's Avatar
if the S1's dont work well with m setup...i will have a set of S2's for back up..
i think i am going with the 3065...
kouzman
63
May 13, 2008 02:44 PM
DynoFlash
41
Apr 25, 2008 07:32 AM
superscout03
38
Jan 30, 2008 09:27 PM
dxbevo9
51
Dec 23, 2007 09:12 PM
evilevo2006
62
Aug 8, 2007 12:51 PM
