What sealer to use on Turbo out to intercooler pipe?
Old Sep 23, 2007 | 08:46 AM
Evil_1's Avatar
I'm have a good leak coming from where the turbo outlet mates to the goose neck pipe. I've replaced the metal gasket twice with no luck. I have the BR adaptor pipe mated to a 20GLT. I have the Ultra Cooper sealer used for exhaust but don't think this stuff will hold 28psi. I don't want to go through the hassle of putting this stuff in just to find out it's not helping. Are there any good sealers that can stand the high temp and the boost I'm running. Thanks
Old Sep 23, 2007 | 03:18 PM
Exciting News's Avatar
When I had mine apart I put a thin bead of regular red gasket maker on both sides. I'm only running 22 PSI, but no issues over a year later.
Old Sep 23, 2007 | 03:43 PM
mfr122887's Avatar
If you are referring to the black pipe that bolts to the turbo, my brother had this same problem. I finally just bought a sheet of gasket material and I cut out two gaskets. After bolting it back up, it was pressure tested and no leaks. I bought it at autozone for like $8.
Old Sep 23, 2007 | 03:44 PM
mfr122887's Avatar
I forgot to mention, RTV didn't work at all. It seems as though the flange was warped when I held it to a flat surface, so I doubled up the gasket and it sealed.
Old Sep 23, 2007 | 05:10 PM
Evil_1's Avatar
Yup, the little black gasket that goes on the stock black pipe. I've took it apart and use the ultra cooper on both sides of the gasket, will see if she leaks tomorrow after it cures. If not, I'll be trying what some of you suggested. Thanks
Old Sep 23, 2007 | 05:29 PM
mfr122887's Avatar
If the sealant doesn't work, def cut ur own gaskets as it sealed 100% with this method.
Heezayx
Oct 18, 2012 10:16 AM
SavageGSR
Mar 11, 2012 02:38 PM
evoforlife
Jul 15, 2010 01:04 PM
nirvevo
Apr 21, 2010 09:57 AM
shunderwunder
Apr 27, 2008 06:25 PM
