FP green turbo worth the price?
I beg to differ. If you talk to Geoff @ Full-Race, which I do on a monthly basis (I am running his products on my S2000 and would run them on my wife's Evo if I went aftermarket), his turbo manifold will make between 10-60awhp depending on the turbo (from OEM to GT35R) with all other variables remaining the same.
Given a stock or stocklike upgrade turbo, with all else remaining constant, the measurable gains in swapping from a well ported stock manifold, such as a BR or PPI, to a tubular header is minimal, and in my opinion not worth the additional cost.
This topic has been well expounded and if there is any proof other than verbal, that going from a BR or PPI ported stock manifold to a Full Race tubular header(or any other header for that matter), on a Green equipped car will gain more than 4 WHP then post the graph.
Personally, IMO a tube header for a stock type turbo is a low returns investment. Eventually, I'll just port my own stock manifold as that's all I can afford to do right now. I'd rather spend my $900 on a Aquamist kit. But hey, that's consumer choice.
If you look around, I believe BR has done extensive testing on manifold & O2 housings. again look around, you'll find it
Also, how fast as your S2k gone?? you said you ran it. I used to have a AP1 S2k and those cars are great. It takes a lot more skill to drive a stock S2k at the limit then a stock evo. I think both handle about the same stock and when super modified. The rear bias (oversteer) on the S2k is much more desirable.
before talkin about power and 1/4 mile times, everyone should know that you can make a bunch of power on any car, just a matter of money and work.
On the stock tip, we all know the evo wins. On the modified tip, evo has the ease of making power as it come factory FI. Doesn't mean a S2k (or even a civic) can't kill an evo, just means they spent a lot more money (mod wise..cuz we know you get your civic cheap and drop a motor, etc) and did more work (swaps, add FI to a non FI car, etc). Also just cuz Honda guy did all that doesn't guarantee he'll win either
Oh yeah, as for my S2k, it got stolen. fu<k thiefs
Ohhh sorry you said ATP "kit" which includes their crap manifold and such. I guess maybe with a different manifold, full bolt-ons, AEM EMS and C16 you could pull 470whp.. but, somehow, I still dont see it happening. The resutls Ive seen with those kits have not been too favorable in terms of dollars spent, spool and overall power.
I was running high 8s in the 1/8 mile when it was N/A, and that was on RT-615s which offered zero traction out of the hole. I haven't ran it since it has gone FI. It has been in the shop more than it has been out. Next March-April will be my first chance to take her to the track.
You don't have to run a 100 shot. The kits come with various jets that allow you to run anything from a 35-150. For a grand you get everything you need. This is getting off topic now. Sorry.
Seeing as how I am the thread starter, I could care less if we stray off topic every once in a while, so long as the overall topic still pertains to mod'n the Evo.
In that case.....
A grand will get you a bottle heater, purge, gauges, and the kit itself. You'll also be smart to toss in an RPM window switch.
100 HP on the motor is 100 HP. Whether it be nitrous or boost it doesn't really matter. The cool thing about nitrous is you normally see better returns from the cooling aspect of it. Unlike high boost, nitrous is very cold. A 75 shot could very well provide 90whp.
Ask around... people have been running 100 shots on 4G63s for years.
1. I am upgrading the rear drivetrain to the inlinePRO R200 diff kit, which is capable of supporting 1000whp. I will be able to run some pretty fat slicks without any worry of breaking the rear end. The car will hook like a mother and the 60' will be pretty damn low.
2. I am sending the cylinder head to Laskey Racing for their Stage 3 head job.
3. I am installing a inlinePRO 3mm headgasket (drops the compression down to 9:1).
4. I am sending the TB to PortFlow for enlargement.
5. I am sending the intake manifold to a guy in the LA area to have him port it, remove unnessecary weight, and then polish it.
6. I am installing a Snow water-meth kit.
The car is currently making over 500rwhp on 91 octane, and will make over 650rwhp with the aforementioned mods and possibly MS109 race gas. I know that what really matters is going out to the track and proving the cars worth, but until I can do that I am simply using other S2000s as benchmarks. These S2000s are making slightly less horsepower than mine and also weigh a tad bit more.
This is a said a lot but I dont think there is any real proof. I would think people think its harder because of the initial torque spike and increase cylinder pressure but you get that from say a turbo as well. As long as the tune is good and the engine is not knocking, youre fine. Also, remember the nitrous isnt on all the time
This is a common myth and not true. If you mean its "harder" because it will produce more torque and horsepower then say adding larger cams or something, I would agree, but adding power whether its from nitrous, turbo, or a bigger cam, its all the same. As long as the tune is good and the engine is not knocking, youre fine.
I think that Soon2B was refering to ATP's crappy exhaust housing design. Greens are capable of equaling your numbers on 93 and besting them on 91, and spooling sooner to boot. According to my math, you still wasted $400.00.
