Can't hold boost!!!
Old Oct 14, 2007 | 09:01 PM
thelza23's Avatar
Can't hold boost!!!
I have so much tapering and was just wondering what I could do to remedy this? Mods are in my sig.
Old Oct 14, 2007 | 09:04 PM
hksevoix's Avatar
boost leak
Old Oct 14, 2007 | 09:08 PM
Warrtalon's Avatar
- The stock turbo tapers
- The more boost you run, the more it tapers
- The higher altitude you're at, the more it tapers
- IXs tend to taper a bit more due to the MIVEC as well
- NEVER make a post about boost before doing a boost leak test
Old Oct 14, 2007 | 09:13 PM
thelza23's Avatar
There is no boost leak, had it checked already. I've seen other members with stock turbo hold the boost better.
Old Oct 14, 2007 | 09:15 PM
Warrtalon's Avatar
Had it checked by whom, with what tools, and to what boost level?
You've seen other members hold it better? What setup, how much boost, what altitude, what method of logging, what altitude, and what mods?
Old Oct 14, 2007 | 09:20 PM
Evo_Jay's Avatar
use ecu controlled boost or a EBC to customize your boost curve, but even though the stock IX turbo will usually taper to about 19-20, which is about where you at. You can get the turbo to hold 22 at redline, but thats really pushing it out of its efficiency range.
Old Oct 14, 2007 | 09:22 PM
thelza23's Avatar
I work at a dealership and had one of the service tech check for me. As far as which member I dont remember exactly, just remember seeing it while searching...
Old Oct 14, 2007 | 09:31 PM
thelza23's Avatar
So this is normal? cant do anything to help besides upgrading turbo huh?
thelza23
Oct 5, 2008 08:04 AM
thelza23
Jul 11, 2008 06:36 PM
thelza23
17
Oct 4, 2007 03:18 AM
thelza23
Aug 12, 2007 06:51 AM
thelza23
Jul 14, 2007 06:07 PM
