Cleaning HKS filter???
Old Aug 11, 2007 | 08:29 PM
thelza23's Avatar
I was wondering if you can use the K&N cleaning kits on the HKS drop-in filter? If not, what should I use to clean it?
Old Aug 11, 2007 | 08:31 PM
boostin23's Avatar
+1^^^^
Old Aug 11, 2007 | 08:33 PM
hytek369's Avatar
bump for an answer
Old Aug 11, 2007 | 08:52 PM
lncrevoviii's Avatar
No you can't clean it with the K&N solutions.
First thing that would probably happen is your MAF getting screwed.
HKS recommend changing it after 3k miles. I used to run mine 4k-5k miles and then just buy a new one.
My advice, just buy a new one. Its no more than $30.
EDIT: Sometimes I used to have bugs or dirt in there, I just used to vacuum it out.
Old Aug 11, 2007 | 09:08 PM
impreza2darksyd's Avatar
Its not washable.. booo, id switch k&n type drop-in filter.
Old Aug 11, 2007 | 09:10 PM
Because, you can use anykind of filter cleaner/degreaser
Old Aug 11, 2007 | 10:23 PM
reeferman's Avatar
Use dishsoap to clean and a thick sticky oil like UNI filter oil. K&N oil is too thin for a foam filter
Old Aug 12, 2007 | 06:51 AM
urslo4n8's Avatar
right. DONT use oil to lube the foam filter. youl suck that **** right in to your intake. I wound up just buying more filters too from HKS, hey, at least they come in diff. colors.
TxFAkuma
May 4, 2016 12:56 PM
Evolution7GSR
11
Aug 21, 2015 01:42 PM
tsidrift1
Feb 5, 2009 07:48 PM
PSIbabi21
16
Sep 14, 2005 09:07 PM
v8killer
12
Aug 5, 2004 10:50 AM
