solid cams?
Old Nov 26, 2007 | 11:53 PM
Underated's Avatar
solid cams?
should i be concerned about running solid cams in my evo head... i know the stock cams are hollow so i just want to make sure... by the way im using blox 272's. i did a search but didn't come up with anything
Old Nov 27, 2007 | 05:36 AM
Ted B's Avatar
Aside from potentially increasing valvetrain noise (increases potential for false knock counts) and increased valvetrain maintenance, there is simply no good reason to use solid lifter cams in this application.
There are 1000+whp EVOs turning 10k rpm without issue using hydraulic cams/lifters, so unless you plan on exceeding this level of operation (which I seriously doubt), you are just inviting potential issues and will likely gain nothing in return.
FYI
Old Nov 27, 2007 | 05:55 AM
rcheung's Avatar
My HKS cams are solid and weigh more than the stock hollow cams. I haven't had an issue with them.
Old Nov 27, 2007 | 06:09 AM
dubbleugly01's Avatar
I think he was referring to solid cams, not solid lifters. The only company I know of that has hollow aftermarket cams is Helix, and not many people choose those. Practically all Evo's that have aftermarket cams in them have solid cams.
Old Nov 27, 2007 | 10:16 AM
Ted B's Avatar
Ah yes, solid cams. I guess I should start drinking coffee . . .
Old Nov 27, 2007 | 12:13 PM
Mr. Evo IX's Avatar
ooops.. sorry, reread original post.
Old Nov 27, 2007 | 04:00 PM
v8hater's Avatar
I never heard of the cam maker, what made you go this route?
I think if you stick to a maker we all know ie hks, buddy club, cossie etc you should not have a problem
Old Nov 27, 2007 | 04:24 PM
Billy@EnglishRacing's Avatar
the midget spec cams are a solid cam, and they work great, ted b is right on with everything he has said
Old Nov 28, 2007 | 11:07 AM
dancarroll0283's Avatar
I think most of the after market cams are solid.... I have the HKS 272's and haven't had any trouble at all.... I know some people have louder lifters, and valves because of it, my car wasn;t affected at all by this... I'm sure weight, and strength is the other real difference between the two.....
Old Dec 5, 2007 | 03:55 PM
Underated's Avatar
thanks for all the replies i was under the impression that the hks and gsc cams were hallow like the stock cams
i went with the blox because they a local to me and my friend has an account with blox
if you guys are interested i can get them for around 260 a set but they only come in sets so no mixing unless different buyers want different configurations
my friend Phil runs www.spoolinperformance.com contact him and tell him Brandon refered you if your interested
b16a95eg
Apr 30, 2016 05:16 PM
motoxxx55
11
Jun 11, 2009 12:44 AM
Forrest Gump 9
14
Sep 27, 2007 06:39 PM
DJ Brett B
Midwest Region
Mar 2, 2007 03:55 PM
rraulston
19
Mar 25, 2006 03:28 PM
