ATP Turbo Kit
Old Feb 21, 2008 | 12:30 PM
  #136
evokel's Avatar
looks good!
Old Feb 21, 2008 | 01:54 PM
  #137
wshihdnevo's Avatar
Originally Posted by jdmrally
how many oil changes have i done on my car??? ... since you know and all. All my town is is 15 second ricers that dont know how to drive so I dont need an 8 second drag car to make money. I don't port my own heads, I pay professionals to port for me, thats what happens when you go to school and get a real job, you have money. You can have your car knowledge, it will never get you money. Thats the difference, whooptie doo if my car doesn't dyno at 500hp then ill get something else, its not like i couldn't afford it. Ive had 3 other 35r setups on my car and used different manifolds and turbos for each one:
The thing is, is that i wanted something that not everyone would see. if you want to show off thats fine and dandy but i dont care, and like a said, if it doesn't work ill just get something else
I hate to get more off track here in this thread, but nothing you have said is really relevant and for someone who is gonna be a doctor your grammar is poor and your excessive use of the comma,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,, is quite retarded. Anyway, don't really understand what relevance your post was supposed to have.
Old Feb 22, 2008 | 01:14 AM
  #138
Gsxtremedsm's Avatar
Hmm I originally wanted a green turbo... However I can get a slightly used ATP 3037 kit for under a grand... Do you think it is worth it? Is the spool that bad? Keep in mind I am running E85 so I should be able to run 26-28psi... Again I would never do this if it wasn't such a good price.
Old Feb 22, 2008 | 04:54 AM
  #139
deadbeatrec's Avatar
i made 503whp with that kit and i like it, not that me saying this means much but just some insight.
Old Feb 24, 2008 | 10:05 PM
  #140
greatgonzer's Avatar
Question
ok I've read this whole thread and now am quite confused. There are some people here making a lot of HP (400awhp range) on stock turbo and simple bolt ons. Here is my setup and I only dynod at 300awhp...What is the deal?! How can I be at 300 and others are at 400 with similar mods:
2006 EVO IX
1: Tubular Exhaust manifold upgrade.
2: 3 inch exhaust all the way to the STOCK o2 downpipe (no cat)
3: Halman manual boost controller set at 21psi
4: Pulsestar spark plugs
5: custom tune by www.Camtuning.com.
I dynod at 300AWHP on 91 octane. How are people so close to 400awhp? The only thing that I see that is different from other setups is that I have the stock O2 downpipe. If I switch that out how big of a differnce will that be? My tuner said that my stock injectors were almost at 80%. I was about to go for a GT3071 or evogreen until I read all of these posts. I'm looking for quick light to light racing and fast spoolup. Now people are mentioning the 3065 turbo. I think that I'm much more confused than when I started reading from page 1. (the sensless bickering is tiresome, but to join in on the fun I am a process engineer and am dept free (except for house and EVO payment). I'd hate to have that debt of the doctor to be...yuck). Any way lets get this post more informative for those of us trying to keep up and decide what do to next...
Old Feb 24, 2008 | 10:23 PM
  #141
RevMoto's Avatar
2006 EVO IX
For one you are in 91 octane. You don't have too many bolt ons. Cams would help out your car a little more, intercooler, ported manifold, and an 02 housing. Normally would get you to 330whp. Some have higher due to a better tune.
Old Feb 26, 2008 | 07:14 PM
  #142
Tarmacisback69's Avatar
revmoto,
i dont see how you dyno'd 370whp on stock cams and 93...
i have basic bpu, turbo xs intercooler hks mivec cams, upgraded hardpipes, 93 pump gas tune @ 21 pounds of boost dyno'd at 363/363 tuned by ams.
is your car some type of factory freak, high reading dyno, or very aggressive pushing the limits type of tune.
Im not bashing you. Pondering minds just want to know.
Old Feb 26, 2008 | 07:22 PM
  #143
RevMoto's Avatar
Originally Posted by Tarmacisback69
revmoto,
Well it is a little bit on the freak side. I have a bad *** manifold on my car too that I don't see in your mod list nor an 02 housing. I can assure you that my tune is better. It is not pushed to its limits either just more tuning time. I am also on 24lbs.
Old Feb 26, 2008 | 07:26 PM
  #144
I have a ported stock manifold, and a megan o2 housing i forgot to list.
I was tuned on the easy side due to a oil pressure problem that is now fixed.
Also my local gas station is 10% ethanol on the 93 pump that might show some type of negative affect i dont know for sure.
Im gonna return with better gas and try to get a retune for 23-24 pounds.
debating on meth aswell.
Old Feb 26, 2008 | 08:42 PM
  #145
RevMoto's Avatar
To be honest we didn't expect my car to dyno this high. I compared manifolds and did logs and so far I have to give credit to the manifold and the freak my car is.
Old Apr 3, 2008 | 08:11 PM
  #146
4G63 T's Avatar
Originally Posted by sabastian458
If you build you own kit you can save a ton of money. I have built a 2.3 stroker with a 3076 for 6k
can you comment on lag
Old Apr 5, 2008 | 04:48 PM
  #147
Yeah I'd like more info on the lag of the 3076 as well. After reading all this, I am seriously considering the ETS HTA3076 turbo kit. Looks like quite the bang for the buck with low lag (if that is true of course).
Old Apr 5, 2008 | 05:43 PM
  #148
crazyitr's Avatar
My ix with stock turbo and mild cams dynoed at 340 whp on a Mustang dyno. I run 116mph in the 1/4. That might be a better indication of power. Your quarter mile trap.
Old Apr 5, 2008 | 05:45 PM
  #149
crazyitr's Avatar
Revmoto's post indicates 372whp and 116 trap speed. That should give you an idea of dyno variances. Don't put too much weight on dyno's. How does the car run? Take it to the track.
evouser12
37
Feb 23, 2007 04:29 AM
blacksheep
Automotosports - Illinois
Jun 28, 2006 09:46 PM
3000ways
23
Mar 9, 2006 01:12 PM
en1gma19
Jan 31, 2004 03:24 PM
Fourdoor
25
Oct 28, 2003 06:50 PM
