HELP>>> My Idle went up then go down and it almost stall......
Old Dec 1, 2007 | 01:35 PM
evovin's Avatar
HELP>>> My Idle went up then go down and it almost stall when I was in the parking lot in Walmart waiting for my wife. It went up to almost 2k rpm for couple second and then go down to 500 rpm but i shut the engine off and turn it on. So far it's running fine. Can anyone tell me what's going on?
Old Dec 1, 2007 | 01:52 PM
colo_evo's Avatar
There are so many things that could cause that...
It sounds like it could be a vacuum leak... thats the first thing i would look for.
Old Dec 1, 2007 | 05:54 PM
evovin's Avatar
really? that's it?
Old Dec 1, 2007 | 08:28 PM
DS-03evo's Avatar
I would check all your vacuum lines...check under the intake manifold, I had them pop off from under there before.
Old Dec 1, 2007 | 08:49 PM
Curt@MrLed's Avatar
Former Vendor
vacuum leak, bov venting the atmosphere, i.a.c. is going bad.
Old Dec 2, 2007 | 01:38 AM
timmiii's Avatar
Your MAF sensor coulg be going bad or might just need to be cleaned.
Old Dec 2, 2007 | 06:54 AM
20Grockit's Avatar
numerous things. vacuum lines, dirty maf, leaky bov. is it throwing a cel???
Old Dec 14, 2007 | 08:46 PM
gvillevo's Avatar
Hey I'm having a similar problem, pretty sure its a vacuum leak, the engine bay was just pressure washed so I figure a line either got damaged or popped off, where are the places that I should check, my bov is not vta and the connection is still tight
Old Dec 14, 2007 | 10:47 PM
BUCKNAKED's Avatar
Wouldn't a loose vacuum line be an automatic CEL??
Old Dec 16, 2007 | 07:27 AM
gvillevo's Avatar
turns out it was my o2 sensor, it threw a code so I'm replacing it.
khay silk
Dec 5, 2015 11:21 PM
hotredevo
Jul 29, 2010 06:54 AM
davemiro
Apr 7, 2010 04:22 PM
gt420hp
Mar 4, 2008 04:35 PM
pumpdog720
Mar 15, 2004 08:26 PM
