Transmission and Differential Fluid Change
Old Jul 21, 2003 | 08:17 PM
Willie's Avatar
Ohh
Thanx Tommy .
Old Jul 21, 2003 | 10:21 PM
Mad_SB's Avatar
Originally posted by iodine23
The only thing I'd be worried about is if there is some kind of break-in additive in the rear diff. I don't know how long they take to break in, but I wouldn't want to prematurely change the gear oil.
mad_VIII: I was thinking of going Shockproof as well. I used to use superlight in my Subaru and I could definitely tell the difference in shift smoothness. I was considering using lightweight in the Evo, but after reading this post, I may just go the same route and use the fluids that Shawn suggests.
Yeah, I like the shock proof, and woul duse it again but I would try the light weight for the tranny and the middle weight for the transfercase.
As far as the rear diff goes, either BG or redline makes a breakin addative for clutch type diffs. I think BG makes the addative and maybee redline has a fluid line that is supposed to help breakin the clutchtype diffs.....
Old Jul 22, 2003 | 08:00 AM
iodine23's Avatar
mad_VIII: There is no middle weight. Uness you mean superlight and light? There is only superlight, light, and heavy shockproof.
Old Jul 24, 2003 | 03:24 AM
shawnhayes's Avatar
Originally posted by QAT-R
Sorry for the newbie question, but just how difficult is this to do. I've a few minor bolt-ons in my previous car but, I never considered changing the tranny fluid myself. And Silversurfer is an efin pimp, good job man!!!
Not that hard, but finding where the transmission drain plug and fill plug is not that easy unless you've done another vehicle before. The tranny fill plug is on the FRONT of the transmission, a somewhat counterintuitive place, but it's pretty accessible.
You'll need a good jack and jackstands, however.
Shawn
Old Jul 24, 2003 | 03:37 AM
shawnhayes's Avatar
If this were the case, they should say that in the manual. BTW, as far as I can tell, there is no real "equivalent" fluid for the Mitsubishi LSD gear oil for the rear diff.
Incidentally, the stuff lists at Mitsu for $50 a gallon. Ick.
By the by, do you REALLY know of anybody whose ever had a problem from premature fluid changing really?
And not the "one time at bandcamp" stuff either.
Shawn
Old Jul 24, 2003 | 03:58 AM
darkcydenyc's Avatar
I was going to change mine and use some AMSOIL Synthetic
DO you think that's a good move?
Old Jul 24, 2003 | 04:33 AM
gtr's Avatar
gtr
Re: Tranmission
Originally posted by Willie
I changed my tranmission fluid at 600 miles and found a lot of metal piece in it and the dealer mechanic tell me get the transmission flush after 3000 miles and it should be clean . And now i have 3600 miles on the clock already make an appointment tomorrow to flush so should i flush it ?
Flush manual trans? Could someone shine some light on this?
Old Jul 24, 2003 | 07:41 AM
iodine23's Avatar
shawn: I haven't heard of any problems. I was just trying to play devil's advocate. So I looked back at RedLine's site and noticed that their diff break in additive is already contained in all their gear oils except 75W90 NS. So in switching over to their products you don't have to worry about not having the "break in" formula or whatever.
Old Jul 24, 2003 | 12:16 PM
shawnhayes's Avatar
No personal experience with AMSOIL myself. Some I've heard is good, some bad.
Redline is all good.
Subnotes: The spec fluids for the EVO from Redline SMELL really, REALLY freakin' bad. Kind of like rotten garbage. Smell like crap, work great.
Shawn
Old Jul 24, 2003 | 12:19 PM
shawnhayes's Avatar
Got it. I've heard all this "changing the fluid too early hurts the car" stuff before. I believe that it's a bad idea to wait too long to change fluids. Cheap. Easy. Most car care advocates agree, too early is better than too late. I know you weren't proposing 15,000 mile changes, but early seems like a good idea to me.
Shawn
Old Jul 25, 2003 | 08:37 AM
Mad_SB's Avatar
Re: Re: Tranmission
Esentially they just pump a metric *** load of clean fluid through the case to ensure that they flush out all the old stuff......... at least that is what I gathered from BG's web site.
Old Jul 27, 2003 | 06:01 AM
berkel's Avatar
Hi all,
Good info here. I've been doing some research as I'm about to do a 30K service in my wife's mostly stock WRX.
The WRX specifies GL5 for the tranny and rear diff (front diff shares with tranny oil). Over on Nasioc, there is a lot of different info, but it seems that NEO oil has an almost universal positive experience besides the cost.
I'm planning on using the NEO RHD in our WRX tranny and rear diff.
I was going to use the same for my EVO when the time comes. It seems that there are different specs for the EVO tranny and the center diff. Some of the issues with the WRX were people putting GL4 spec oil into the tranny (like redline MT-90) when the tranny specifies GL5. Our EVO however does specify GL4 for the tranny.
Hmmmmmm, I've used Redline MT-90 in my Integra and really liked it, and it seems to fit our application. The WRX guys seems to have mostly negative among people who used the Redline 75-90 in their tranny, at least among those who posted. They cited that it was too slippery and caused a lot of grinding when shifting. Anyway, it seems that with the few people that have used redline for the EVO, it's working very well. If I can get rid of the decel noise as well, that would be an added bonus.
Does anyone know what NEO products would fit our requirements? The NEO RHD is GL2-GL6, but I don't know what we should use in the tranny that is GL4 spec equivalent...
On a side note, when I brought my car in to get Lojack installed (500 miles), I spoke to the dealer regarding the decel noise which they acknowledged after a ride-along. I have a case with Mitsu, which will hopefully help me out if I have issues down the line. They drained my tranny fluid and there were no metal shavings, but at least I have fresh fluid, heh. This did not really help with the decel noise, so I hope another fluid, and/or changing the diff fluid may help?
Thoughts?
Sorry for the long *** post! Lots of info swimming around in my head, lol.
Take care,
FB
Old Jul 19, 2010 | 12:08 PM
boczo777's Avatar
so which one for tranny and which one for transfer case?? i wanna go with redline but im getting confuse
superalf574
Jun 26, 2009 10:12 PM
Denverwhitetrac
Feb 27, 2007 09:10 AM
MYEVOVIII
Jan 9, 2007 08:36 PM
undrcroft
Oct 21, 2005 12:42 PM
runny_yolk
Apr 12, 2004 08:09 PM
