no one has GL4 oil for tranny?!?!
i tried searching but the basic idea i came up with is that GL4 is still the standard for the tranny gear oil but i can't get it? I'm doing my first fluid change so i go to the dealership(big one in Nashville) and they don't sell the fluid. They say go to autozone so i do and they don't have any GL4 fluids avail. Only GL5. Autozone calls the dealership and they say GL5 is OK.
Is this new?
All the posts i read have never mentioned GL4 not being avail.
'05 evo by the way.
Trust me i always search and this is my first topic i've started so please help.
Is this new?
'05 evo by the way.
+1, any GM dealership will carry the synchromesh, works well too!
Originally Posted by mdosu
order BG Syncroshift from Lancershop.
or you can try Pennzoil/GM Syncromesh...I dont' know where you can pick this up.
From what i know GL-5 is not to be used in the tranny only GL-4, if you can not find it order it if you have too and keep driving till you can get it. Can use Pennzoil/Synchromesh or Redline MT-90 or the GM stuff is the same as the Pennzoil. if you have to spend more to Order it and have it sent 2 day Are i think it is worth it your Car cost over 30 Grand what is 20 or 30 dollers to 2 Day something in it is only 3 Quarts.
Originally Posted by DaWorstPlaya
+1 for Pennzoil Synchromesh ... its like $5 a quart ... same stuff as BG synchroshift and GM stuff ...
Syncroshift is made by Pennzoil and is the same as Synchromesh...
i haven't found any documentation that says:
You MUST use GL-4...if you use GL-5 you will destroy your transmission.
I use AMSoil...its actually SAE rated and GL-4
https://www.amsoil.com/storefront/mtg.aspx
Sorry about the confusion, I'm not saying its the same oil, I meant to say that BG synchroshift and Pennzoil synchromesh are the same type of gear oil that promote better synchro performance. BTW the stuff GM sells is Pennzoil just relabeled and more expensive ...
I heard somewhere on here that Syncroshift and Syncromesh was the same stuff just relabled again...
so I didn't know if someone can confirm this.
thanks for the replys. I just couldn't beleive no one had gl4 in the nashville area. I didn't want to use the GM stuff and risk getting a the tranny warr. voided.
Even if its a small risk. I just order the Amsoil stuff. heard thats some good shizzle. Not too expensive either.
audiofan
10
Oct 26, 2015 06:35 AM
jcnel_evo8
62
May 15, 2006 01:08 PM
