35r and what i need
Old Dec 19, 2007 | 12:40 PM
Shaun@AWDMotorsports's Avatar
35r and what i need
Ok I want to do the 35r on my car but i need to know all what I will need to do this. so far i have all the stuff in my sig. I know I will prob need a head gasket, head studs. But what eles will I need . I have a few questions also
factory intercooler is good for what hp
Walbro 255 fuel pump is good for what hp
Old Dec 19, 2007 | 12:48 PM
junction's Avatar
You will need an upgraded intercooler fo sher. Down the road maybe do cams and injectors and go from there.
AMS has it on sale for the holidays for $650. Just picked one up myself. I plan to do a 35r in Spring/Summer.
Old Dec 19, 2007 | 12:49 PM
scottatyamaha's Avatar
You need to learn how to use the "search" button
Old Dec 19, 2007 | 12:51 PM
evilbada's Avatar
You need to worry about other things before you worry about head gasket.
You dont' need head gasket, head studs unless you are running more than stock boost.
Stock intercooler will not be efficient with 35r so plan to upgrade.
You need bigger injectors along with that walbro.
Basically you will need
A good turbo kit put together by a reputable vendor such as AMS, BR, ETS, FR etc etc
Bigger injectors to support fuel for added air. (720-1000cc0 depending on the power level.
Upgraded FMIC and pipings to keep the air cool.
Camshafts to help spool, midrange, top-end power
Head studs and possibly gasket if you're running higher boost pressure.
Good multiplate clutch to hold power level.
Built bottom end for 500whp+ power level for insured safety
Built tranny, transfer case if you will be drag racing alot.
hope this helps
Old Dec 19, 2007 | 12:54 PM
MartinD's Avatar
Old Dec 19, 2007 | 12:58 PM
Tvwj's Avatar
Just go all out. The more stuff put in the more stuff going to break so might as well just go all out.
Old Dec 19, 2007 | 01:46 PM
HeRtYIXMR's Avatar
i heard the buschur HTA 35r kit is the best bang for your buck
Old Dec 19, 2007 | 03:00 PM
G20's Avatar
G20
you need to know what're you getting into. The most pactical thing that you need is a lot of cash.
Old Dec 19, 2007 | 07:23 PM
ray3328's Avatar
search button is your friend...
Old Dec 19, 2007 | 08:46 PM
CrackerJackToy's Avatar
Alot of topics readily available via the search.
But in a nutshell, fmic, piping, 780cc injectors, good tune, cams.
STOMPER!
17
May 20, 2019 03:51 AM
Lucas English
41
Jun 11, 2007 01:24 PM
tuning g
Jan 22, 2007 02:11 PM
Crzbiasmr
Automotosports - Illinois
55
Jul 17, 2006 09:52 AM
SALEVO
12
Mar 24, 2006 07:39 PM
