Balance shaft remove or not ??
Old Dec 19, 2007 | 11:42 PM
vboy425's Avatar
I do a lot of road racing with my track evo. I have balance shaft eliminator kit right here in front of me, I have been thinking about having the balance shaft remove. What are you guys thought about it ? remember this is an track/road course evo. So keep it in our remove it ?
Old Dec 20, 2007 | 12:03 AM
Johnboy1065's Avatar
I'd do it. ya make a little more power. and it takes stress off of the oil pump so it will last longer. which is good since your in the higher rpm's a lot with a track car.
Old Dec 20, 2007 | 04:55 AM
EvoTech's Avatar
I road race and drag race my car as well and I was back and forth about doing it. Really this is the only thing holding us back from spinning real high RPM. I ended up removing the rear shaft and machining the front shaft to a spindle. Essentially is is the same as the one AMS sells for about $300. You simply bring it to a machine shop and have them put it on a lathe and take off the counter weights. It only costs about $40. The stubby shaft has been used for years on DSM's and many evo's run it as well, but I can't recommend it. I have personally seen 2 oil pump falures that were running the stuby shaft. I can not say that it was a direct result of the stubby shaft, but I have my suspicions. I can honestly say that I feel no difference in vibration even with poly engine mounts. The car rev's quicker and I am very happy that I did it. Now I can feel safe when I bring it up to 8500 RPM or higher. Hope this helps.
Old Dec 20, 2007 | 09:38 AM
duracell55's Avatar
Remove them, they will be one less thing inside your engine that can cause problems, specially for what you use the car
Old Dec 20, 2007 | 09:42 AM
SiCKlEyWiKeD's Avatar
If it's a track car I would say remove them. When I was building my motor I was thinking about taking them out. I DD my car to and from work and everywhere else so I decided to keep them in.
Old Dec 20, 2007 | 01:43 PM
vboy425's Avatar
thanks everyone.
Old Dec 21, 2007 | 07:42 PM
vboy425's Avatar
damn Evotech is charlie akak C-spec the guy who tune your evo way back. how r u bro ? yeah 50% toldme do it and the other 50% say don't
babaz7
Jun 5, 2013 07:16 AM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
EE
Feb 25, 2008 06:49 AM
Celica2EVO
Jan 30, 2008 08:16 AM
Dr Crash
Lancer Engine Tech
Jul 8, 2004 11:38 AM
