GM MAF + intake size
Old Jan 1, 2008 | 05:32 PM
steadly2004's Avatar
Its the same thing, I think just a different diameter. There is even a setting when installing it to switch from 3" to 3.5" if thats the MAF you have. Its the flip of a switch. I don't know anything about 4" MAF though, never heard of them being that big.
I stuck with a 3" MAF blowthrough, I dunno. Just thought it was enough for my application. And maby it would read the air more accurately if it wasn't oversized. Thats the only downside when I read up on Camaro's and them upping their MAF size, the consistancy of the metering.
Originally Posted by dan l
If your running a VTA BOV you need to be running blow through after the BOV. The 3" GM MAF works well on 2.5" IC piping. If your running draw through then you want the biggest model you can find to limit restriction. I ran a 3.5" draw through. I've ran both ways and they both run the same. The draw through is nice because when you boost leak the AFR's richen up and you know there is a problem. The blow through is nice because you can VTA when you need to run that big tial. If running blow through make sure you aren't spraying water or meth as when it hits the sensor it will kill it.
I am actually planning on adding methanol injection. As long as I am spryaing after the MAF, this shouldn't be a problem right? I mean I'll only spray when in the higher PSI anyway, and the air is only flowing in one direction.
Old Jan 2, 2008 | 12:26 AM
AznDragonV's Avatar
thanks ^^^
ok. I plan on putting this GM MAF 3 inch or 3.5 inch on the UICP somewhere, does anyone know how far down i should get it cut? But if i get the 3.5 in MAF then I'd have to get a 3.5 inch UICP right? or would i loose any power from just getting reducers?
STM Tuned
Jan 10, 2025 11:51 AM
IbeBOOSTIN
Nov 2, 2015 07:30 PM
Moore Auto
Vendor Classifieds
15
Sep 4, 2013 10:25 AM
ETS Michael
Jun 10, 2011 09:06 AM
ProStreetOnline
Lancer Vendor Classifieds
Mar 31, 2005 12:01 PM
