My Compression Pressure Test! Comments?
Old Dec 29, 2007 | 09:17 AM
joedr's Avatar
EvoM Moderator
Thumbs up My Compression Pressure Test! Comments?
For those of you that are dealing with Evos everyday,
I decided to do a compression pressure test to see the health of the valvetrain, gaskets, etc.
I am looking to get the more experienced guys on Evos to comment if this results are normal or whatever case may be. I followed the instructions on the manual: Warm car at normal temp, remove cables and plugs, remove crankshaft sensor and WOT during the test. Per manual, normal pressure should be 1128-951 kPa or 163-138 PSI.
Note: I used the compression tester that you find at PepBoys! FWIW!
These are my results:
Piston 1:
Piston 2:
Piston 3:
Piston 4:
Old Dec 29, 2007 | 09:49 AM
dxbevo9's Avatar
nice
Old Dec 29, 2007 | 09:55 AM
joedr's Avatar
EvoM Moderator
Seems that piston 1 is like in the bottom of the tolerance per manual. I do not think that the tester itself is a little off. It sits below the 0 mark.
dxbevo9.... I think that you mean that the numbers are looking OK! Right?
Old Dec 29, 2007 | 10:05 AM
cfdfireman1's Avatar
Did you follow step #1?
1. Before inspection, check that the engine oil, starter and
battery are normal. Also, set the vehicle to the following
conditions:
• Engine coolant temperature: 80 − 95°C (176 − 203°F)
• Lights, and all accessories: OFF
• Transaxle: Neutral
Old Dec 29, 2007 | 10:10 AM
joedr's Avatar
EvoM Moderator
Yes! I followed that! I am using the mini battery and I think that the cranking was a little slow comparing to a bigger higher amp battery.
I left the engine to reach max temp. It was running for like 10 minutes and a 83 degrees ambient temp.
Old Dec 29, 2007 | 08:01 PM
mrfred's Avatar
Hey joedr, the spec for Evo IX compression measurement is 92-145 psi. The cylinder to cylinder max variance is 14 psi. The numbers you have are for an Evo VIII.
Old Dec 29, 2007 | 08:16 PM
joedr's Avatar
EvoM Moderator
Thanks for the info mrfred!
I though they were the same and the manual I have is in fact for the VIII.
So, I guess that I am good to go then!
Old Dec 29, 2007 | 08:33 PM
grenade's Avatar
FWIW on my 05mr, with 280 cams, it was 145 all the way across the board.
Old Dec 29, 2007 | 08:36 PM
steadly2004's Avatar
Hmm.... Just to throw it out there, my stock 4g64 read 185-190 across all 4 cylinders. I don't think I'm supposed to have that much higher a compression ratio, like 9 to 1 stock. And I have the exact gauge as in the picture, only from advanced auto.
I did buy a straight pipe that screwed into the cylinder, I didnt' think I could get the flimsy hose to screw in completely.
Old Dec 30, 2007 | 02:59 AM
dxbevo9's Avatar
yes bro i meant they look good.....they are very consistant!
Old Dec 30, 2007 | 02:33 PM
joedr's Avatar
EvoM Moderator
I guess that based on the actual specs for the IX (Thanks mrfred), seems to be in pretty good shape then.
Old Dec 30, 2007 | 05:16 PM
mrfred's Avatar
Looks fine to me, esp considering the PP gauge. :-)
n2oiroc
21
Feb 22, 2018 05:06 PM
reklisss
Feb 25, 2016 07:26 PM
n2oiroc
Midwest Region
Apr 14, 2014 01:59 PM
luischav3z
02-03 Lancer Show / Shine
67
Mar 28, 2013 11:07 PM
n2oiroc
Apr 4, 2012 07:07 PM
