revs don't come back to idle
Old Jan 4, 2008 | 03:42 PM
rovanpera's Avatar
Question revs don't come back to idle
please help, anyone:
2006 bone stock 9 mr, 37kmiles. i accelerate normally in firts and second, and then brake (or coast), clutch in. the revs take FOR EVER to come back to idle. sometimes this is also apparent on downshift, such that the car fights the brakes.
no check engine light, gas pedal free, gas linkage lubricated (i was concerned it does not go back the the sheath), return spring on the throttle body works perfect, idle rock steady, no abnormal noises.
this started about two moth ago, and is intermittent.
thanks for any thougths on this,
peter
Old Jan 4, 2008 | 03:45 PM
bluebanana23's Avatar
check your vacuum lines
Old Jan 4, 2008 | 03:47 PM
rovanpera's Avatar
ahhhh, vacuum lines, ahhhh, perhaos you can suggest a diagram or an old post? i looked but i am not sure i can tell what actually is vacuum....
pk
Old Jan 4, 2008 | 03:59 PM
krazirob's Avatar
like how long does it take for the revs to come down
Old Jan 4, 2008 | 04:09 PM
DrivinMissDaisy's Avatar
My IX does the same thing. When I gun it in first or second and push in the clutch and don't shift to the next gear, my RPM's come down slow. It is almost like I am in gear, engine braking, but i am not.
I talked to some one and they said it had to do with emissions. How? No idea.
Old Jan 4, 2008 | 04:11 PM
Ph3n1x's Avatar
What does you TPS voltage read when this occurs.
Log you car if you can...
Leaning towards vaccum leak.
Old Jan 4, 2008 | 04:56 PM
krazirob's Avatar
well he is gonna need evoscan or something.............but vaccum leak does sound like the issue
Old Jan 4, 2008 | 04:58 PM
Chemwarrior's Avatar
Sounds like another case of throttle hang. Do a search on that and you will find many posts.
Old Jan 4, 2008 | 08:18 PM
lurkerpika's Avatar
pk
uninstall.
Old Jan 5, 2008 | 07:05 AM
rovanpera's Avatar
so this is what i got from the throttle float (hang):
1. BOV spring too stiff and
2. HOWEVER, this is just a partial cause, the Base Idle Speed Setting is a bypass valve, as is the Idle Stepper Control Valve, both let air past the throttlebody, and when you have a firmly springed valve, slight excess boost pressure, and a ICSV setting or BISS setting to increase idle speed to prevent some types of stalling, you will get the idle hang/raise..
i am still at a loss whys this happened after 2 years of owning the car, how to fix this, and how to diagnose this wihtout ambiguity so that i can stick the stealer with the cost of repairs.
Old Jan 5, 2008 | 07:57 AM
rovanpera's Avatar
i still cannot understand this: do we need to adjust the idle stepper table because there is no way to trick the clutch switch ? are there two clutch on/off switches or only one? why throttle hand is elimienated by the double triggering of the clutch switch???
thanks,
Old Jan 5, 2008 | 08:14 AM
BlueDemon's Avatar
If it feels like it takes 4-5 seconds for the rev to come down in first after reving it to redline and putting the gear in neutral after that, then is just a normal thing for evos. A tune fix that lil' issue for me.
Your case sounds like it's happening on normal and high loads so the throttle is hanging for no reason. Yeah u better log the car and from there determine what is going on. Also check the vaccum lines and the throttle cables for sure.
kyoo
42
Jun 23, 2017 11:29 AM
ezzey
May 9, 2016 09:40 AM
DanielM
Apr 12, 2016 11:33 AM
Evo47
Dec 10, 2015 09:46 AM
EvoVan
Nov 5, 2015 05:28 AM
