DP hitting, how to fix
I got an evo8 and an aftermarket 3" downpipe. it is hitting the ACD/Gearbox in a place.
what i wanted to know is how i can fix it. would hitting it with a hammer (to bend it slightly) do the trick or a blowtorch or something else would be a better way to fix it.
thankx
thankx
Getting a DP that fits is what would work. Id say return the one you have or sell it, then get one that fits, dont beat the **** out if it.
Btw, ive got one for sale
sounds like you have a downpipe from an '03-04 model which has a smaller transfer case. u need to resell that downpipe & look for one that is for a MY05 or newer EVO...
ahh its is a JDM spec car, and when i got the DP i told them to send me the proper one. its not hitting badly just a light tap i think. but still would like to fix the problem.
thankx for the help
thankx for the help
which would pull timing and make your car slower
yep that is why i want to fix it. but i have another problem that is causing phantom knocks as well :-( as going back to the stock DP decreased it a lot but not completely there.
as a side note, when you are doing two step (with the stationary rev limiter) do you get knocks then??
