Coolant leak, replace banjo bolt, gasket and ??
Old Jan 15, 2008 | 11:04 PM
EvilTechnology's Avatar
I've had to add coolant twice in ~900 miles since I had a bunch of work done, including a shop installing a Green.
So anyway I was checking around the engine bay tonight and felt under the coolant line on the front-side of the turbo, the one with the 21mm banjo bolt and my fingers came up wet with green (coolant).
So I tried to tighten it but could only get about 1/8th of a rotation on it. So I plan to replace the banjo bolt and the copper seal ring, they look a little corroded.
Anyway, anything else I should do? Do I need to apply anything to the threads of the bolt or anything?
Kind of a ***** to get to it, I was using a shallow 21mm 1/2" drive, as it's the only the 21mm I have. Any ideas to get to it easier and get better leverage, without removing the upper rad hose or overflow line?
Thanks
Old Jan 16, 2008 | 08:25 AM
bump
Old Jan 16, 2008 | 12:20 PM
barneyb's Avatar
The copper washers shouldn't be reused. BUT, they get reused. There is no need to replace the bolt unless damaged.
Yank the rad if you need room. Torque the bolt to 31 ft lbs.
Old Jan 16, 2008 | 01:23 PM
Thanks. I know they shouldn't be re-used, but by looking at it, I think the shop did re-use it.
Old Jan 16, 2008 | 03:32 PM
barneyb's Avatar
It??? There's 2 washers on each banjo bolt.
Old Jan 16, 2008 | 03:42 PM
yeah there are 2 there, one of them looks haggard. Ordered 2 of them, dealer was out of stock.
MechNARP
24
Oct 10, 2017 06:52 AM
06mr775
Sep 30, 2015 02:33 PM
KJS
11
Sep 1, 2012 06:11 AM
Boost3dxEvO
Feb 15, 2009 07:39 AM
nicolas916
11
Oct 10, 2008 04:11 AM
