I just replaced my broken Oil Feed Banjo Bolt and got this???
Hi all!
I broke the stock Banjo Oil Feed bolt that mounts at the right side of the Head..
My stock Banjo bolt had a VERY big opening in the center for the oil to feed through..
I am thinking that Mitsu possibly designed the Banjo bolt to make it sturdier so that it wouldn't be so easy to break.. When they did it, they made the banjo hole to allow oil to pass through.. smaller? I am just wondering if this bolt is okay to use?
I ordered through Russell at Mitsu on here.. and he claims that every one that replaces that broken Banjo.. He sends this one to.. And this is the factory part number.. He has never had any questions regarding the difference in the OEM banjo oil feed bolt and this one though.. so I thought I would post. Please help me!!!
Here is a pic of the new one.. The old one is broken and I threw it away already.. If any one has a picture of the stock one with large opening, please post it up!
Thanks again!!!
Thanks again!!!
It is a little smaller but I wouldnt worry about it. If you ever look at a 35r, look at the -an reducer going into the turbo. The whole is at least half the size. The turbo will be fine and get plenty of oil. I will post pictures after i pull my turbo off this weekend.
When oil is pushed through that hole it is under pressure, whether the hole be smaller by say a couple of mm and or 1 cm, will most likely have no adverse or harmful affects on your car. If you are that paranoid about it your only option would be to drill out the hole slightly larger say a couple of mm and or a cm.
Thats because dual ball bearing turbos need alot less oil. But to the OP, that banjo bolt will work fine.
Creamo3
12
Apr 3, 2009 04:31 PM
Wizard_of_Evo
44
Aug 31, 2004 09:52 PM
