DP failure from Heat Wrap?
Old Jan 20, 2008 | 11:42 PM
mrfred's Avatar
Every Evo DP I've seen is now made from 304 stainless steel. This stuff can easily withstand any corrosive environment brought about by heat wrap. Its worlds more corrosion resistant than mild steel.
Old Feb 3, 2008 | 01:51 PM
ducker's Avatar
What do u think about this? Did anyone do this to the hotside?
http://www.designengineering.com/pro...sp?m=sp&pid=31
Old Feb 3, 2008 | 02:00 PM
c kim's Avatar
i would just get a good ceramic coating, especially if you live in a 4 season state. Another thing you can do if you want to reflect heat from your oil pan is getting some adhesive heat reflecting tape stuff. Made by dei I think? That shiny orange stuff, you know what i'm talking about.
Old Feb 3, 2008 | 02:03 PM
c kim's Avatar
You drive all those cars and you think getting a little downpipe coated is a pricey option?
Old Feb 3, 2008 | 02:40 PM
Ted B's Avatar
Stainless is more resistant than carbon steel, but 304 is a mild grade, and given enough time, will eventually degrade.
It's all just a matter of time and heat.
Old Feb 3, 2008 | 03:42 PM
JKav's Avatar
In general, you're better off shielding the heat-sensitive components than the heat source itself.
So in this case, it'd be smarter to apply heatshield mat to the oilpan rather than wrap the downpipe. Especially considering that the performance advantages of wrapping the dp are essentially unmeasureable.
By applying a thermal mat onto the oilpan, you will achieve the same end result this way (i.e. preventing heat from reaching the oil) without inducing unnecessarily high thermal stresses in the downpipe.
Old Feb 3, 2008 | 04:10 PM
mrfred's Avatar
A wrapped 304 SS DP would hold up perfectly well to temperature in a clean environment. It could even be argued that the use of a wrap on the DP would reduce temperature gradients across the DP wall and thus reduce thermal stresses. :-)
Corrosion could be the bigger issue. Salt embedded between the wrap and the DP could accelerate corrosion if moisture can make it to the surface of the DP. With high temperatures though, it seems like its unlikely any significant amount of moisture would be present.
Old Feb 3, 2008 | 09:20 PM
JKav's Avatar
That's true, the gradient is less severe, but the bulk average temperature skyrockets when you wrap the dp.
Same situation occurs with thermal blankets on turbine housings--they get cooked to death, warping and cracking in all kinds of unnatural ways.
soderdna
Feb 17, 2015 07:42 AM
thewiz11144
Lancer Engine Tech
Dec 18, 2011 11:21 AM
Thugline
31
Jun 4, 2007 05:27 PM
hanzie
Oct 27, 2004 04:06 AM
wojo
21
Mar 5, 2004 02:15 PM
