Fidanza Flywheel not mating with 03 starter
Old Jan 23, 2008, 06:29 AM
Mr. Evo IX's Avatar
We are working on a 03 Evo that was taken to a transmission shop to have the clutch replaced. They put it all back together and the starter and flywheel do not engage properly (bad gear mesh). The tranny shop thought it was a defective flywheel and the owner ordered another (same Fidanza flywheel). Anyhow, the owner bought the Fidanza combo because of a review on THIS board. So either the review was bogus and it doesnt fit or we have defective parts TWICE. We are going to have to tear the car down to find out of it's an install issue but that's unlikely because there's only 1 way to put a clutch on a Evo.
A. Who has this Fidanza flywheel / Fidanza clutch working on their 03? Also did you have any starter / flywheel issues?
B. The flywheel / clutch combo was purchased from lancershop, not sure where the second one came from. Do you all think that the part can be returned? Should I tell the owner to get his CC company involved right from the start?
C. The Fidanza flywheel gear does not even match the stock flywheel gear, it's about 1/16" larger diameter than the stock unit.
Old Jan 23, 2008, 08:54 AM
cfdfireman1's Avatar
No way to shim the starter out 1/32"?
Old Jan 23, 2008, 09:04 AM
Mr. Evo IX's Avatar
Were going to try that and possibly even modify the starter gear. The thing is that these parts should fit. If it were my Evo I would send all the Fidanza gear back and get an Exedy or ACT. Really I was wondering if anyone else has had this problem, although their clutch is not very popular, their flywheels seem to be commonly used on this board.
Old Jan 25, 2008, 10:45 AM
mithrandir7533's Avatar
Which combo
I just bought the 3.2 Fidanza combo from buschar racing. I plan to have this installed next week. Please update. Thanks.
Old Jan 25, 2008, 06:13 PM
justboosted02's Avatar
i have an 03 with a fidanza flywheel and my starter made a loud screetch (sounds sort of like a supercharger) untill i removed shims from the starter
Old Jan 26, 2008, 06:01 AM
ACTman's Avatar
My guess is that they probably got some bad ring gears from their supplier. If that is the case no amount of starter shims will help. You should probably contact Fidanza directly to let them sort it out.
Old Feb 2, 2008, 05:01 PM
Update
Well, after getting my clutch installed I'm getting a loud grinding when I start car. Its random on when the starter gear will mate with the flywheel. I pulled the starter off and examined it. I can't tell if the starter gear is moving to far out and hitting the stop ring or if its not moving out far enough to full engage the flywheel. I plan to take it back to the shop and have them examine it more.
Old Feb 20, 2008, 10:43 AM
Turns out my ring gear on the flywheel was machined incorrectly. The beveled edge to aid starter engagement was on the wrong side.
Old Jun 18, 2008, 09:36 AM
Mr. Evo IX's Avatar
Were you able to get Fidanza to resolve the matter? We have 2 bad flywheels, 1 on a car, 1 in a box. We were able to get it to work without grinding 95% of the time it doesnt have this problem. Unfortunatly the car that has the Fidanza got rolled on Friday the 13th. But we still have 1 bad Fidanza flywheel new in the box that we need resolution on.
Old Jun 18, 2008, 09:39 AM
PATRICK B.'s Avatar
Wow that sux to hear guys.
I would hope Fidanza would take care of that issue.
Old Jun 18, 2008, 09:54 AM
EvoM Moderator
scheides's Avatar
WTF you guys, call freaking fidanza and work it out with them!
I have the 9.5lb flywheel on my car and there was zero fitment issues. Furthermore, zero driveability issues like you'd expect from a fly-weight flywheel like this. I love it.
Old Jun 23, 2008, 02:52 PM
Mr. Evo IX's Avatar
Not knocking Fidanza, in fact I love that carbon 3.2 clutch. But the flywheel def has an issue and this is the first time I've seen someone else have the problem.
We thought it was with the car we were installing it in and now we know it's not the car's problem.
Old Jun 26, 2008, 09:21 PM
Vapor's Avatar
still running my 3.2 with flywheel, absolutely no issues Sorry to hear that you have, but I think if you call Fidanza you will be happy you did. Please let us know what happens
Vivid Racing
EvoX 'For Sale' Engine Internals and Drivetrain
26
Jul 29, 2010 11:29 AM
jasonsrt4
May 18, 2010 03:44 PM
Thegame
42
Jul 23, 2009 07:46 PM
Smike
16
Nov 8, 2008 09:34 AM
93civEJ1
21
Mar 15, 2005 10:41 PM
Quick Reply: Fidanza Flywheel not mating with 03 starter
