new at this new 2.0 build
Old Feb 17, 2008 | 08:38 AM
  #31
Ludikraut's Avatar
Originally Posted by possessedimport
the car will be used for mostly drag strip but i would like to try circuit but thats last on my mind. this will also be a everyday driver as well even though it wont be driven everyday and will be raced when there is a potential car like honda's where i came from and muscle cars. basically ill be dragging it some times ok heres my new list
crower rods
eagle pistons
exedy twin disc hd clutch
supertech springs & retainers
HKS 272 cams
arp head bolts
ams vsr manifold with 75mm throttle body
buschur racing double pumper fuel set up
1000cc injectors
93 + meth
buschur racing hta gt35r tubular manifold kit .63ar
buschur racing intercooler kit with tail bov
aem ems
3" turbo back
tell me what you think and what i should add because i know some things are missing
What RPM are you looking to rev to? If you're planning on revving past 9000 RPM, then you may want to think about removing the balance shafts, since they spin at twice the RPM as your crank.
- You're listing a 75mm TB, but there's no mention of 3" IC piping.
- Eagle pistons? I don't think I've heard of Eagle making pistons, but I could be wrong...
- You didn't list adjustable cam gears. HKS 272's definitely do not run optimally at 0/0. If you don't want to use adjustable cam gears, you may want to look at different cams, such as GSC
l8r)
Old Feb 17, 2008 | 04:06 PM
  #32
possessedimport's Avatar
yeah i see that i made a couple of mistakes
je pistons
buschur racing 65mm tb
hks cam gears
im looking to rev to only 9000 rpms
Old Feb 17, 2008 | 04:14 PM
  #33
Ted B's Avatar
. . . tell me what you think and what i should add because i know some things are missing
When someone begins talking about a 67mm turbo, HKS 272s, 650hp, and 9000rpm in the same context, those all-too-familiar red flags start waving (we see them often).
As for what I think, you'd be far for the wiser to invest more time in researching and reading about the results from various combinations before you start assembling a grocery list.
Old Feb 17, 2008 | 04:35 PM
  #34
David Buschur's Avatar
Just a few things because I sent you a PM.
EAGLE RODS suck if you are planning on 500 whp or more. We don't even sell them anymore. We use to and I sold A LOT of them. Then we started seeing them fail on a regular basis. For those saying how great they are, they just aren't making enough power and running enough RPM. I will not sell them.
You will need our double pumper or AMS's or other options, a single 255 won't work.
1000 cc injectors will be good for about 600 on our dyno and our dyno reads low.
AEM EMS or some other fuel management.
Forget HKS 272 or 280 cams. The Jun 272's are good, Tomei 280's our BF272's.
I've had no problem with Supertech dual springs, ever.
One last thing. THE MAGNUS INTAKE MANIFOLD I TESTED IS AN OLD DESIGN THAT IS NOT MADE ANYMORE. If you want to run his new stuff get it, I have not tested it.
Old Feb 17, 2008 | 11:21 PM
  #35
JC evo1's Avatar
what cams would be best for maxing a 35r on the old head? How come you dont make your BF272's for the older evo's and dsm's, i would definatley buy some if they were available
Old Feb 17, 2008 | 11:36 PM
  #36
ONRAILS's Avatar
Please don't over look GSC S2 cams. I've been looking into these and have herd very good things.
I've also herd the JUN 272's and BF 272's are pretty close in respect of cam #'s.. BOTH BADASS cams. The japenese cams are a little too pricey for me. I would run the BF or GSC. That simple.
BR race fmic is the only option also. PT67 turbo might be a little too large for daily driving for you.
Old Feb 17, 2008 | 11:41 PM
  #37
Done's Avatar
go with gt35r if going to drive on street.
gidz
May 21, 2012 08:32 AM
FathouseFab
277
Aug 2, 2011 06:41 PM
evolvd276
Nov 16, 2010 09:10 PM
Batmann!
May 3, 2006 08:26 PM
TeenEVOwner
30
Jan 21, 2006 01:12 PM
