ATP kit strikes again!!!!
Old Feb 11, 2008 | 08:26 AM
  #61
deadbeatrec's Avatar
Originally Posted by hokiruu
Deadbeat obviously doesn't really care about, or isn't going to change his setup because of anyone's opinions or suggestions regarding his setup, so I just hope he is satisfied with the car and enjoys it. The feud between Scorke and Deadbeat is entertaining. Please take it to the strip for once and for all. You both always say you are down, so just do it already or stop talking so much $h!t on each other's threads!
Deadbeat: they must really salt the **** out of the roads up in Albany! All the corrosion made me cringe a little, but I give you props for apparently driving the car on the street a lot all year 'round, which is what matters to me! Just too bad they don't switch over to the cinders they use out here, it's much nicer on the cars.
well this will be the last year i drive it during the winter.
Old Feb 11, 2008 | 08:34 AM
  #62
V8 Eata's Avatar
Originally Posted by deadbeatrec
i do not. link please.
http://ttp-engineering.com/catalog/p...c9b8b4df9c82c6
Old Feb 11, 2008 | 08:37 AM
  #63
V8 Eata's Avatar
I would get a re tune with the coils and tell Al ~ I don't care about the numbers tune me for the fastest spool and TQ
Old Feb 11, 2008 | 08:39 AM
  #64
V8 Eata's Avatar
Al's tune is a very consistent tune I mean look at it.
But I think maybe if you sacrifice a little HP and tune for more TQ your car could be faster.
Old Feb 11, 2008 | 08:40 AM
  #65
V8 Eata's Avatar
Im just trying to help.
Old Feb 11, 2008 | 08:41 AM
  #66
mrdevo's Avatar
How high can this turbo be run to? I wouldn't think more than 35psi. Considering the pull was done after 4000rpms the spool isn't as bad as has been seen. Wouldn't the spool be a little quicker if the pull was done at 3000rpms? Or maybe all it takes is 1000rpms for the kit to hit full boost? Either way I think the numbers are impressive despite a small hit in spool.
Old Feb 11, 2008 | 08:48 AM
  #67
V8 Eata's Avatar
^ I agree
Old Feb 11, 2008 | 08:53 AM
  #68
DougoeFre5h's Avatar
Oh they almost definitely did the pull from a lower RPM, but scaled it afterwards for the picture...why, I don't know.
Old Feb 11, 2008 | 09:42 AM
  #69
trying to help with what? u think i care what other people think about my choices? haha. im happy and last time i knew, i was the only one driving it. and i know the spool isnt bad at all. this is my third turbo and by far the best in terms of power and driveability.
Old Feb 11, 2008 | 09:48 AM
  #70
V8 Eata's Avatar
Post the video. I want to see it.
Old Feb 11, 2008 | 10:07 AM
  #71
tabio42's Avatar
Scorke-
I want to compare something. I'm not measuring penises or touting the ATP kit. I will be switching to something else in the future. When I bought mine it was really cheap and it is stealth for us CA guys. But I know it is restrictive to peak power. I want to get an idea of what the spool difference is since we have similar setups.
You have a 2.3 with which 35r kit?
I have a 2.3 with the ATP 35R with the .63 AR turbine housing on the stock exhaust manifold. The exhaust manifold and turbine housing were extrude honed together as one piece so the crappy transition was fixed. Due to some material being removed from the turbine housing, it is not truly a .63 but close enough.
I consistenly get 22 psi at 4150-4250RPM loaded up in 3rd gear on a flat road. 27~ psi comes another 100-200 RPM later. I just recently started over with my tune so I wont have any high boost logs but I'll try to get a 3rd gear 22psi log and post it. (I have to remember to switch from kPa to psi )
Where does your car spool?
Old Feb 11, 2008 | 10:12 AM
  #72
another thing, as mentioned in my defense in another ATP attack thread, was that on the dyno, the spool up is different due to the varrying loads than on the street.
if u want, i will take a video of the boost gage and tach when i get the car.
V8, please re-read my post.
Old Feb 11, 2008 | 10:20 AM
  #73
So moral of the story, deadbeat's car is making great power and he is happy with its spool time and powerband.
I think the thread title might tend to spark some fierce scrutiny for the ATP haters, I think DB will admit that as well. All things considered, that is one hell of a daily driver.
I still want to see a dynojet dyno, 2.0L 30R non-ATP pull @ around 28 psi. If we're talking anything less than 500 RPM difference then I'd have to say its negligible for street duty.
Old Feb 11, 2008 | 10:23 AM
  #74
only one i can think of on here is the Full Race twin scroll. thats just not a fair comparison. at almost 4x the cost of the ATP kit, i would hope it spools faster
Old Feb 11, 2008 | 10:52 AM
  #75
V8 Eata's Avatar
trying to help with what? .
Im trying to help you with your misfire problem so you can crank up the boost.
