This has been bothering me for the longest time...
Old Feb 23, 2008 | 03:27 PM
HighwayStarX's Avatar
When I start up my car in the morning when I depress the clutch pedal after turning the key to start it, the car seems to slightly jump foward a bit. Now it doesnt happen lets say when I turn it off and turn it on a bit later only in the morning it usually happends. Any idea why?
Old Feb 23, 2008 | 03:29 PM
Dont Try To Run's Avatar
Maybe your clutch is adjusted a little bit too much? That would explain why it does not happen once the clutch is "warm" and expanded a little bit more... Have you adjusted your clutch pedal at all?
Old Feb 23, 2008 | 03:31 PM
No I havent adjusted it yet. Regarding the clutch pedal, it seems like its more stiffer then my old MR was. I was thinking it might need to be adjusted.
Old Feb 23, 2008 | 04:26 PM
BBS's Avatar
BBS
Is this on a stock clutch?
Old Feb 23, 2008 | 05:01 PM
jpetro10's Avatar
mine does the exact same thing, but ONLY when its cold or hasnt been started in a while. If i start it after being driven it wont happen. I have no idea why, but i just changed tranny fluid and this seem to help out a bit?
Old Feb 23, 2008 | 05:08 PM
Yes its on the stocker (at least i think so i bought the evo im currently driving used)
Old Feb 23, 2008 | 05:53 PM
itsme4g63's Avatar
Mine does the same thing, on a exedy clutch. I haven't bothered to adjust it though, as I should, it catches pretty high and gives me engagement issues sometimes.
Old Feb 23, 2008 | 05:59 PM
KazzEvo8's Avatar
I posted about this years ago and was told it was clutch adjustment or I was nuts. Hope to see a real answer.
Old Feb 23, 2008 | 06:08 PM
aspensvt16's Avatar
Lightbulb The fluid
Well when the fluid is cold or even room temp your gears in your tranny basically act like a auto trannys torque converter. Moving cold fluid can move gears that are not together. Weather its in nutrail or not. Thats what i would guess. Then when the fluid warms up it gets thinner and moves more freely. I know i had a 30 below weather here in ND and my car dies evey time i let out the clutch. HAVE TO DO IT SLOWLY.
Old Feb 24, 2008 | 12:55 AM
well i am going for some parts install and tune soon so i guess ill see what the tuner says
Mweisel
Feb 23, 2018 02:08 PM
ssth
Jun 16, 2017 01:17 AM
95lsvtec
33
Jan 28, 2009 10:58 AM
Mitsu_Evo_MR
Nov 5, 2008 06:43 PM
bboy_RES
Jan 29, 2008 08:03 AM
