Just got tuned by Ivey overboost?
Old Feb 28, 2008 | 01:50 PM
gamebred26's Avatar
yeah dude it is the street...the cold weather...the load..
always see a diff reading on the highway then the dyno...all that cold air hitting the ic..
adjust it a little
Old Feb 28, 2008 | 05:27 PM
jdmdc2r01's Avatar
Thanks for all the info everyone.
Sean Ivey, I emailed you about this but did not get a reply back so I posted my question on this forum to see opinions...
I will turn the boost down so I get 23psi.
Thanks again.
Old Feb 28, 2008 | 06:36 PM
U2SLO's Avatar
A very good friend of mine had his car tuned by Sean and it's over in Europe now.
It has yet to miss a single beat and runs amazing.
Old Feb 28, 2008 | 06:45 PM
qwon526's Avatar
also keep in mind the greddy profec reading of psi may be off alittle as well - it may be a good idea to have another accurate boost gauge to verify.
whats your set gain % at? i believe this should be around 4psi less than your targeted boost.
Sean@Iveytune's Avatar
Thanks again.
I could have sworn I replied to you, sorry if I didn't I get confused sometimes :-)
Either way just turn it down a bit, when you were tuned we had discussed it I told you i liked 23psi, you wanted more I told you more won't blow the engine but I still recommend 23psi.
Sean
Old Feb 28, 2008 | 06:48 PM
We used a mechanical boost gauge on the dyno to set the actual boost.
It's a little autometer boost gauge on the dyno table that we whip out for that purpose.
Sean
Old Feb 29, 2008 | 08:44 PM
jdmdc2r01's Avatar
My set gain is at 15%, my gain was at 80% but I turned it down to 72% getting 23/24psi on profec's reading.
Anyone know if greddy reads to high or to low?
Shy
Apr 10, 2010 07:57 PM
4WS Tuning
Jan 11, 2007 01:45 PM
Johnny Boy
Southeast Region
18
Aug 25, 2006 11:27 PM
Jadiem
Mar 2, 2004 05:54 AM
rizalhoo
Jan 26, 2004 09:29 AM
