F%$& lots of damage to MOTOR???
Old Mar 2, 2008 | 03:45 PM
boostGotMeLaid's Avatar
Originally Posted by DynoFlash
Post a pic of all the spark plugs
Are the injector clips on and the plugs secure ?
AL
clips are secure they are brand new injectors oh could i test it??
Old Mar 2, 2008 | 03:46 PM
Originally Posted by 4WS@TopLevelAuto
spin the motor by hand.... see if its smooth or has a little hiccup.
Cheers!
with the plugs out or in??
Old Mar 2, 2008 | 03:51 PM
DynoFlash's Avatar
How are the other spark plugs ? Are they all melted or just one ?
Old Mar 2, 2008 | 03:54 PM
U2SLO's Avatar
Before you do anything,pull your oil stick check oil level, and condition of it,is there any in it??,does it smell burnt?? does it look milky??,don't just start trying to fix it yourself especially when you could have a very serious problem.Don't go any further on it until you pick up the phone and speak with the persons that built it,then whom tuned it.You could add insult to injury by trying to play A-tech.
Old Mar 2, 2008 | 03:56 PM
TTP Engineering's Avatar
You have a garbage (worse than stock headgasket), a garbage turbokit, and a tune from an unknown tuner. What did you expect to happen.
Sounds like severe detonation or preignition, melting the plug.
Old Mar 2, 2008 | 04:02 PM
crcain's Avatar
Bad injector is what people always first guess at when it comes to a blown motor but I really doubt this happens often. I wonder if the tune you had used AEM knock control.
Old Mar 2, 2008 | 04:03 PM
wow im speachless
Old Mar 2, 2008 | 04:07 PM
Bimmubishi's Avatar
If the injector doesn't fire there's no ignition event so it's not going to melt anything on one pull in 3rd gear. If the injector was squirting 1/2 the gas that it was supposed to then I can see how there'd be damage but a complete shutoff is a different story.
Old Mar 2, 2008 | 04:12 PM
Pr3z's Avatar
wow im speachless
He tells it like it is man. Sorry.
Old Mar 2, 2008 | 04:16 PM
i know by speeking with the tuner there will be nothing accoplished i signed a waver so idk i checked the dipstick right when it occured everything was fine level was fine and block and gaskets where good from what i can see
Old Mar 2, 2008 | 04:20 PM
DynoFlash's Avatar
This is very true - i have seen examples with a partially connected plug and or partially clogged injector which resulted in melting of spark plugs.
When the plug comes off there is no fuel to burn anything so no damage
Often it can take deterctive work to track down the cause of a failure of this kind.
The OP should try to determine if his AEM box was set for for internal logging or not
Al
Old Mar 2, 2008 | 04:22 PM
i didnt even get a chance to go over the maps thats how soon this all happen
Old Mar 2, 2008 | 04:26 PM
Al
i can fined out what happen monday when the shop is open about how he did the AEM
but are yall talking about the plug wires wernt connected??
Old Mar 2, 2008 | 05:00 PM
the coil pack was bolted on so i know the plug wire was in correctly im still confused on what had happen i wish i was logging or somthing
