P0090 Fuel Pressure Solonoid Circuit
Old Mar 17, 2008 | 07:02 PM
05-EVO-GSR's Avatar
I recently changed my intake manifold (seperate thread coming up) and I accidently crossed two connectors. I put the injector clip for cylinder 1 on the Fuel Pressure Solonoid and the Fuel Pressure Solonoid clip on Injector 1. After starting up the car and realizing that I made a mistake I changed them back. The car runs fine but now I have a P0090 code that will not go away. I check the resistance on the solonoid and it is within spec at 32 ohms (manual says 25 ~ 35 is OK) I checked the voltage at the connector and it is a 12.6 with the key on and 13.7 with the car running so I figure that is ok as well. I am afraid I did something to the ECU internally. I will also try a different Fuel Pressure Solonoid to see if that makes a difference.
Can anybody offer any advise?
Old Mar 17, 2008 | 08:51 PM
RoadSpike's Avatar
You did clear the code right?
If not pull the negetive on the battery and flip on the headlights for a couple seconds.
Old Mar 17, 2008 | 11:01 PM
05-EVO-GSR's Avatar
Tried a different Fuel Pressure Solonoid and that did not make a difference.
I have cleared the code but it keeps coming back. I will try a different ECU to see if that helps.
hatesposers
Feb 16, 2023 05:35 PM
05-EVO-GSR
Feb 23, 2017 11:57 AM
EVO8YEA
Mar 18, 2016 10:44 PM
ahowelltech
Jul 18, 2015 11:45 AM
