check transmission
Old Aug 1, 2003 | 08:46 PM
inline4g63's Avatar
check transmission
How do i check the transmission fluid? I can't seem to find it. Also is the intercooler spray just normal water, distilled water, or some special fluid?
Old Aug 1, 2003 | 08:47 PM
Diesel's Avatar
normal water in the IC spray bottle...
Old Aug 1, 2003 | 09:22 PM
JeffWels's Avatar
its washer fluid in the intercooler spray bottle. I do not recommend "normal water" or tap water in the spray bottle because of mineral build ups. For the summer you can run distilled water if you like. I just wouldn't recommend tap water.
Jeff
Old Aug 1, 2003 | 09:45 PM
ChillinEvolved's Avatar
In Timeout
ive been usin spring water in mine lol
Old Aug 1, 2003 | 10:02 PM
bishiboy's Avatar
trans
the trans isn't fluid it's gear oil in the transaxel. You need to get under the car and look for a plug on the side to remove and check the level. The oil should be right at the bottom of opening, just like a manual trans oil check (or rear diff). I haven't been under mine to check but that's the way you check every other transaxel.
It's not a dumb question though, I need to look under mine and check it too.
Old Aug 3, 2003 | 09:25 PM
erioshi's Avatar
You really souldn't need to open up the plug to check the tranny fluid (gear oil) unless you notice gear oil seeping from any of the tranny seals.
If you do plan to open the fill hole, be sure to purchase a new crush washer for the plug from the dealer before putting it back in. If you're going that far; it's only another short step to drain and re-fill the tranny with fresh fluid. Doing that removed most of the tranny whine I heard while decelerating.
Old Aug 19, 2003 | 11:28 AM
runny_yolk's Avatar
Where does one get the crush washers for the tranny fluid drain plugs? I called all of the Mitsu dealers in my city and none of them carry it. Further more, they quoted really high prices for these washers if I wanted to order them.
Manual Trans: $4.64
Transfer case: $1.60
Rear Diff: $1.26
What sizes are these washers? Are they available elsewhere?
Old Aug 20, 2003 | 07:20 AM
iodine23's Avatar
I don't remember the washer being a crush washer. It's just a flat piece with a slight "seat" on one side for the bolt head. I just reused the original washers when I changed my fluid.
Old Aug 20, 2003 | 08:22 AM
runny_yolk's Avatar
So in reality those washers are gaskets and not crush washers like the oil drain pan? Excellent, that will save me from having to purchase at the crazy prices that the dealer parts department was quoting me.
thanks!
Old Aug 20, 2003 | 09:51 AM
limey's Avatar
Yep...the trans and transfer are regular washers
Ghilversumtuner
Lancer Tranny/Drivetrain Tech
23
Apr 11, 2019 09:28 PM
Big Bald
Jan 3, 2014 04:54 PM
johnnycage
11
Dec 10, 2012 07:46 AM
boostedscooby 5
Jan 7, 2010 07:39 PM
Seitz
14
Jun 26, 2006 03:06 PM
