Unofficial HKS EVC VI thread.
Old Aug 4, 2011 | 07:38 PM
  #91
boostedwrx's Avatar
Bump for old *** thread. Has anyone tried higher than 100% offsets? I was trying 110% with a boost target of 33psi (really 30psi on MAP sensor) and was getting around 32 peak so I almost want to try 120% offset but that got me thinking why the fugg does it go to 200%??
Old Aug 5, 2011 | 07:06 AM
  #92
TURBODAWG's Avatar
Turn it up to what you need to het your desired boost. 200% will max out the stepper motor. That boost controller can only provide 37 psi so the manual says. At 200% it will try to run 37 psi as nest it can given the dynamics of you whole setup.
Old Aug 5, 2011 | 07:27 AM
  #93
SmurfZilla's Avatar
Most complicated EBC EVAR. Best decision I made was getting rid of it. Sure its a great EBC....setup is un-neccesarily difficult. Good luck
Old Aug 5, 2011 | 09:14 AM
  #94
boostedwrx's Avatar
It's not complicated, it installs like every other EBC I've ever had and the basic setup is easy as well. Select wastegate type, wastegate boost, target boost, done. It's all fine tuning from there. Only thing I DON'T like about the gauge is that is about 3psi off the MAP sensor.
Old Aug 5, 2011 | 01:46 PM
  #95
SmurfZilla's Avatar
I've used everything from a basic greddy profec b to a apexi avc-r and I never could get the HKS setup right. I ended up getting rid of it and going ecu controlled. The new tuner I'm using doesn't like ecu controlled boost all that much so I'm now going with a AEM truboost.
Guess I wasn't smart enough
Old Aug 5, 2011 | 05:35 PM
  #96
boostedwrx's Avatar
You'll really like the Tru-Boost. If i get rid of the EVC I'm going BACK to the Tru-Boost. I used one for a while, it was super accurate and easy to change boost.
Old Aug 5, 2011 | 09:05 PM
  #97
SmurfZilla's Avatar
Perfect. Got the 75 PSIA sensor so it will see over 30 PSI
Old Mar 24, 2014 | 09:13 PM
  #98
azzaevoviii's Avatar
bringing up an old thread does anyone know where i can get my hands on the EVC guide that TURBODAWG put together, I would PM him but his profile says his last activity was on Oct 29, 2011 04:05 AM
SWOLN
Oct 15, 2015 11:07 AM
chueu
14
Mar 15, 2011 11:34 PM
BLKCarbonEVO
15
May 29, 2010 09:11 AM
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
TheAngryTiTTy
11
Mar 13, 2008 11:48 PM
