Evo Turbo Information
Old May 11, 2004 | 08:34 AM
  #91
TurboMaestro's Avatar
Originally Posted by Baby Viper
Can someone get more information on the Evo VI T.M.E. turbo set-up?
Sorry, TME? WTF?
Old May 11, 2004 | 01:36 PM
  #92
gunzo's Avatar
TME = Tommi Makinen Edition Evo VI special
Baby viper, 1st page of this post gives you the info you require..
Old May 11, 2004 | 01:41 PM
  #93
Baby viper, just search yahoo w "tommy makinen edition", I found all kinds of pages.
Old May 31, 2004 | 01:44 PM
  #94
PitoPocket's Avatar
anybody know the psi of the stock turbo of an evo 8??
Old Jun 17, 2004 | 05:04 PM
  #95
earthman's Avatar
19 psi max
Old Jun 20, 2004 | 10:36 AM
  #96
zmeli's Avatar
Usdm Rs
checked the P/N no HRA. guess the info is not correct or We get screwed. I wolud have liked having the alloy turbo.
Old Jun 20, 2004 | 11:19 AM
  #97
bishiboy's Avatar
I've got 25psi out of my stock turbo. Peaks to 25 and tapers down to 23 at redline (7850rpms).
Running it at these pressures will shorten the life, the efficiency range is lower (20.5psi can be run without adding excessive heat to the charge air).
Old Jun 30, 2004 | 12:31 PM
  #98
evo400's Avatar
Registered User
guys you will all find your turbo will probabley make various boost levels . all the tho5hr turbo will run @ 2 bar with the correct adjusment on the wastegate /actuator . to my extensive knowledge there have only been 3 turbo ever made with revesre rotation .
powerstroker diesel turbo garrett
kkk made a unit that was used in competition @3 bar boost
renault F1 used a reverse rotation turbo .
i have blades for all theses units and some are for sale as a evo turbo ultimate upgrade . both the KKK and renault wheels are solid Ti 5 axis machined units .
Old Jun 30, 2004 | 08:39 PM
  #99
Zeus's Avatar
So the blades are for sale separate?
Old Jul 1, 2004 | 12:06 AM
  #100
EVO correct me if I am wrong, but you would need a compressor housing specific to that compressor wheel, no? A lot of turbo/machine shops over here will not machine housings to fit, they claim to not have the tools.
Also EVO, you are forgetting one reverse rotaion wheel, the 20g-r and the Garrett 60 trim r.
Old Jul 1, 2004 | 10:56 AM
  #101
evo400's Avatar
Registered User
tm mate we can do any turbo profiling you like ! we have all the machines you could ever wish for !garrett ihi combo etc etc . can you supply me with either of theses wheels tm !!!
Old Jul 1, 2004 | 12:55 PM
  #102
If you can imagine it I can make it.
Old Jul 1, 2004 | 09:27 PM
  #103
Zeus's Avatar
So well over 400whp on pump gas, that spools quicker than stock?
Old Jul 1, 2004 | 09:30 PM
  #104
Yes, and is edible as well. :O
Talk to EVO400, he has the high HP applications.
Old Jul 1, 2004 | 10:19 PM
  #105
Zeus's Avatar
I am fishing...
