German Castrol VS Amsoil
Old Mar 26, 2008 | 04:56 AM
deadbeatrec's Avatar
ok so there is a huge debate going on in other forums that is argueing which oil is better.
here are a couple links
http://forums.corvetteforum.com/show....php?t=1468080
http://www.c66racing-synthetics.com/...20Analysis.htm
and for referance, here is what some of the terms mean if u dont already know.
http://www.c66racing-synthetics.com/...toroil.htm#TBN
so basicly, this thread is for the oil gurus and anyone who wants to get into this debate.
i want some real numbers. i want dyno results, used oil wear analysis, 4 ball wear tests, ect..
ready, set, GO!!!!!!
Old Mar 26, 2008 | 05:10 AM
Davo's Avatar
amsoil would always be my weapon of choice
Old Mar 26, 2008 | 05:13 AM
when i started using Amsoil, the car was never smoother. this past winter b4 i had the motor torn down, i had cheap mobile 1 in it, and i have never herd so much valve noise in my life!
Old Mar 26, 2008 | 05:24 AM
Davo's Avatar
i switched from mobil 1 to amsoil in an almost virgin engine(bought car used) and no issues
sorry no test data here but other guys with mitsu engines have reported valve noise when using mobil and it being reduced when using shell
Old Mar 26, 2008 | 06:49 AM
MR Turco's Avatar
Good article. I use the GC in my sentra and have never had an issue - coming from mobil 1 which would get so thin it would leak past the rings.
The best part is Autozone has some really good sales on castrol every now and again. They recently had a sale where you got a mobil 1 filter and 5 quarts of any syntec for $26. I returned the filter for $11 and that is the best $15 oil change you can get!
Old Mar 26, 2008 | 07:21 AM
im about to try the new SSO from amsoil. got a wix filter and im ready to feel and hear the difference in my newly built motor.
ps. has little over 1000 miles on it right now with regular oil.
pss. the new SSO is 0w30 which is said to act like a 10w30 as well as a 0w30
Old Mar 26, 2008 | 07:50 AM
heated debate this is not.
come on guys! maybe i should post a pic of my girlfriend pouring these oils all over her bare body, i bet then u would all post.
ps. mods im not thinking about it, just saying. haha
Old Mar 26, 2008 | 08:01 AM
long read about GC
http://www.bobistheoilguy.com/forums...643#Post718643
and if u ask me, some of it, from what i understand is incorrect.
Old Mar 26, 2008 | 09:10 AM
Mike01gsr's Avatar
pixorban kthxbai ..lol I am would love to hear some info also PM Oil doc and
he could put his two cents in as he sells amsoil. I'm going with the SSO this
summer also!
Old Mar 26, 2008 | 09:13 AM
summer also!
i have PMed him and he said he was going to look into it.
this GC has a HUGE following.
i just want to know how it compares to the new SSO.
Old Mar 26, 2008 | 09:41 AM
scherejs's Avatar
The first few oil changes I put Mobil 1 in mine and since then I've been running GC in my car. I've always like it and seems to be doing well with 86,000 of hard driven miles.
Old Mar 26, 2008 | 09:50 AM
have u ever used Amsoil? would u be willing to try it and see if there was any differance?
Old Mar 27, 2008 | 05:22 PM
Oil Doc's Avatar
I am doing a little more checking into this.
From what I have found out so far is that it is not a bad oil. In some "tests" the AMSOIL edged out the GC. The oil used was AMSOIL 0W-30, the old Formula TSO it looks like.
AMSOIL reformulated the 0W-30 about 8 months ago and has increased the TBN which is the ability of the oil to Neutralize acidity. Acidity comes from oil being contaminated by combustion by products and water vapor.
The other additives packs in the new SSO were also beefed up.
I noticed a couple posts and see these type quite often about "I've used xyz oil and never noticed a problem"
Key word, NOTICED.... You have no idea what is happening internally, Rust, Corrosion, Wear, Heat...
I am going to see if I can find an MSDS for the GC... It may give a little more insight into what the oil actually is... I find it hard to believe that it is a 100% Synthetic @ $6.50 per qt.
Doc
Old Mar 27, 2008 | 05:34 PM
Oil Doc's Avatar
SECTION VI: PHYSICAL/CHEMICAL CHARACTERISTICS
Boiling Point: ND Specific Gravity (Water=1): 0.86
Vapor Pressure (mm.Hg. @ 25 °C): ND Vapor Density (Air=1): ND
Percent Volatiles: Negligible Evaporation Rate (BuAc=1): < 0.1
Freezing Point: -22°F to -40°F (-30°C to -40°C)
pH-Value: NA Viscosity Range @ 100° C, cSt.: 5W-20 5.6 to 9.3
5W-30 9.3 to 12.5 10W-30 9.3 to 12.5
Odor Threshold: NA 10W-40 12.5 to 16.3 20W-50 16.3 to 21.9
0W-30 9.3 to 12.5 5W-50 16.3 to 21.9
Coefficient of Water/Oil Distribution: ND 5W-40 12.5 to 16.3
Appearance, Odor & Physical State: Clear, amber liquid; mild petroleum odor
This didn't lay out how I copied it, but the line I highlighted indicates that this is nothing more than a Hydro-Cracked oil.
As I said, a good OIL..... Just not Good Enough...
AMSOIL will pour at -60 plus
Doc
U2SLO's Avatar
Switched from ENEOS to AMSOIL yesterday 20-50 runs perfect,engine sounds a little quieter also.
