GSC S1 cams
Old Mar 26, 2008 | 08:44 AM
2 step's Avatar
Question GSC S1 cams
So I have decide to get S1 setup for my evo8. Just wanting to know if anyone has had problems with S1 cam setup or if it made reliability go to ****? I was thinking of not using APR head studs?
Old Mar 26, 2008 | 08:45 AM
mitsuboost30's Avatar
def get the head studs!!! and from what i hear they are awesome cams!
Old Mar 26, 2008 | 08:47 AM
whitersevo's Avatar
yes indeed. they are awesome cams... you will be happy with your purchase.. get the head studs also..
Old Mar 26, 2008 | 09:08 AM
Boostin4g63's Avatar
Honestly u dont need to have any kind of supporting mods with the GSC or the HKS 272's. Now if you go with GSC S2's then u might need it. I have HKS 272's and i love it. Didnt even need to upgrade the valve train. Matter of fact i have a brand new set of head studs (unopened/still factory sealed with the reciept).
If your interested shoot me a PM.
But again u dont need them.
Old Mar 26, 2008 | 12:21 PM
broeli's Avatar
Unless you have the time/$ to put head studs in correctly and plan on running high boost (above 22)..I wouldn't worry about replacing them.
Old Mar 26, 2008 | 01:50 PM
Burklow's Avatar
+1 I've been corrected on this before. I thought they were a must have item, but many high boost meth guys do fine with stock ones.
They are excellent midrange power cams.
Old Mar 26, 2008 | 01:52 PM
joseph k's Avatar
Greg(GSC) has a lot of knowledge and a very extensive background his cams are by far some of the best around. and please search the site instead of posting without searching
Old Mar 26, 2008 | 08:57 PM
fugiwara's Avatar
+2, I've been correct by Sean Ivey about the headstuds too, he said you don't need them for cams. As far as running 22psi goes, the stock ones will do the job just fine. Most people change the headstuds when they upgrade their cams, but again you don't need them.
Old Mar 26, 2008 | 09:04 PM
CA$H's Avatar
This is the truth.
Your bottom end will give before the Evo stocker head studs will. This was a problem with the DSM not the Evo. Hey if it makes you feel better do them but, the correct way to install is to take the head off. Good Luck.
Old Mar 27, 2008 | 02:59 AM
Nissan2Evo's Avatar
GSC S1 are great low-end midrange cams with decent top end. You will enjoy them. Keep the stock headstuds though, no need to jump on that bandwagon.
Old Mar 27, 2008 | 07:48 AM
Aby@MIL.SPEC's Avatar
I think the gsc s1's are the best all around cam out there.
awesome drivabilty / city driving characteristics & offer great linear power throughout the rev range.
oem head bolts are fine too.
imhenryd
23
Sep 20, 2015 01:25 PM
Boostin Perform
EvoX 'For Sale' Engine Internals and Drivetrain
47
Mar 17, 2014 06:05 AM
okevolutionVIII
May 2, 2013 05:18 PM
EvoSupersonic
Dec 12, 2012 10:37 AM
Wht9er
Feb 15, 2011 07:29 AM
