Full Race Twin scroll Results!!! GT35r
This car generates about the same peak hp vs. boost as my 35R did with regular .63 A/R T3 hotside. The difference is this car spools much better, has a better torque curve, and undoubtedly feels 100% better to drive on the street. That's the difference TS makes.
The issue has never been faster spool it's always been is there a loss in top end and when you factor in the increased price is it worth it?
Waiting for someone to actually push any TS 35R kit to 36+ psi and maybe we will see.
Sigh... look at the numbers a little closer ca$h (with a screen name like that I'd think you wouldn't give a crap about "7 large"). This is at 23 psi - look at the torque and boost onset. There's no pleasing peak number people like you. He has at least 10 psi more to play with to hit the numbers you "think" it should. The car is hitting torque values 400-500 rpm sooner than before without losing top end. What more do you want?
thats true...most of the opinions that are negative are those looking at the big number... and not whats below the curve... it peaks at the same hp numbers but everything below where you car is is where it counts...for ts...i drove the car and it makes other 35Rs seem extremely laggy or soft down low...once he gets the other cams it will probably be even sicker
That was with 35r. It now has even more with the HTA35! Good ole open scroll..
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Yea, good ole open scroll. That's why nearly every OEM uses TS on their turboed cars, because it sucks so much.
Let's see the graph. Is that with a stroker? If not, your out spooling every 35R I've seen on a 2.0 and that includes all those high power HTA cars from David. Those hit the same 200 lb ft around 4000-4100 rpm and that's on his Mustang dyno.
My second point all along is that doing a true back to back to show it spools faster is VERY difficult. No one has actually done what I would call a good back to back. A 63 housing spools faster than a 82 because it is more restrictive. I have seen 63 open spool faster than an 82 and not loose any hp up top. I would call this finding the ideal a/r housing for the setup. Switching to TS and getting better results CAN be attributed to finding the ideal a/r as well. How can you prove which is responsible for the gain? the ideal a/r gains or TS gains? Its difficult.
I have a good friend locally that did a twin scroll swap on 3071. That is to say he switched from the 63 open to the 78 TS. The car lost 400rpm spool and made 40hp less on the TS. what this means is for that particular setup the 63 a/r open was just far more ideal a/r for the setup. No TS benefits were realized.
What are you going to say when buschur bolts on a TS 35r finds he cant make that same killer power with it? people maxing out turbo setups could care less about what is happening at 3-5000rpm. Are you going to change the hype to "great for auto-crossers" but not good for drag racers?
