CBRD secret sauce turbo upgrade!
Old Oct 19, 2008 | 03:17 PM
  #721
blackdemon's Avatar
Great numbers charlie Cant wait to see what you can do with my car next week.
Old Oct 19, 2008 | 03:24 PM
  #722
EvolutionBoy67's Avatar
Sorry i got another question. Someone in this thread mentioned they were upgrading to an AEM. How much more power could be made by going stand alone?
Old Oct 19, 2008 | 03:39 PM
  #723
Exciting News's Avatar
Originally Posted by kreionic
OK heres my graph from the dynoday. My power was still climbing i think another 200-300 rpms i might have seen another 10-15hp.
That is just bad ***.
Old Oct 19, 2008 | 04:15 PM
  #724
EVO8LTW's Avatar
Nice that we have an FP Red dyno to compare to the BBK lite dyno on the same day, same dyno, both 93 octane:
I guess the key differences are that the BBK was running 4 less psi, but had a Buschur head and a sheet metal intake? I think the Buschur head has proven to be at least 20 whp in a 400 whp application, plus it should allow for more timing advance without knock? I don't know what to attribute to the intake manifold. Buschur advertises a 15 whp gain for a ported stocker and a 65 mm TB. And I'm not sure about the cams at this boost level.
The spool-up looks pretty similar between these two turbos as far as I can tell. I assume that the BBK with the turbine upgrade will spool a little slower but make more top end power?
Old Oct 19, 2008 | 04:20 PM
  #725
Shacochis06's Avatar
Note:
I have a stock IC/ charlie has a buschur race core
m2's/ charlie is on s2s
stock block & head/ charlie buschur st3 head
stock intake mani/ JMFAB intake mani
Not really apples to apples....i think the bbk well have spool up and midrange from there on out its all red....
This thread is about the BBK not the red
  #726
kreionic's Avatar
Agreed matt.
This is NOT an apples to apples comparision. That was not the point of this. Both in my opinion are good turbos. They each have there place. You can not compare these two cars. I didnt want to post the graphs for this reason. Way to many differences. Like I and you said. I have a head, different cams, IC, and JM fabrications intake mani.
But to answer some questions. I cant really say what the head added. I swapped from S1 to S2 at the same time then a week later the manifold went in. There was a very noticeable tuning tolerance for knock with the head. I can finally run timing in my car. I would guess a like 200 or rpm spool lose with the turbine(again i could be wrong). I am expecting a 10-20hp and tq jump from the turbine wheel
Old Oct 19, 2008 | 04:32 PM
  #727
Like charlie said above both turbos are frickin awsome...its up to whatever the customer wants but you cant go wrong with either
Old Oct 19, 2008 | 04:34 PM
  #728
kreionic's Avatar
Please try and keep each turbo in there own threads. I understand fully that people will compare these turbos. Its just natural to do so but nothing is remotely close with these two cars with mods. If people do its starts well the head is worth xx hp so subtract xx hp his cams are better no his are better etc...
Old Oct 19, 2008 | 04:35 PM
  #729
EVO8LTW's Avatar
I understand you guys are friends and don't want to step on each other's toes, but anyone interested in either of these turbos is going to want to compare them.
Old Oct 19, 2008 | 04:39 PM
  #730
First i dont think its a matter of stepping on each others toes since we both could really care less....this thread is for the BBK tho and updates of whats going on with its production....if you want to compare the two start your own thread
I know people want to compare the 2 but keep this one on the BBK....
  #731
kreionic's Avatar
very true its the nature of the beast. I just think there both great turbos and each of them have there place. Like you said people will compare them no matter what. I just dont want this or Matts threads to get turned into a pissing contest thats all
Old Oct 19, 2008 | 04:44 PM
  #732
EVO8LTW's Avatar
Okay okay...over and out.
Old Oct 19, 2008 | 04:45 PM
  #733
+1 Charlie
Old Oct 20, 2008 | 05:14 AM
  #734
Sully 18's Avatar
looks like top graph has more power to go...bottom graph shows it dies out at 7k
Old Oct 20, 2008 | 06:49 AM
  #735
jbrown's Avatar
Maybe that's because the top graph is from a car with a Buschur race FMIC, Buschur Stage 3 head, JMFab intake manifold and more aggressive cams?
The bottom car has all stock pieces in those locations and milder Cosworth cams so of course it won't make as much power up top..
