Registered User
Quote:
Originally Posted by jbrown
It will only help in that there might be a slightly smaller pile of metal on the floor when they are done machining it for the new turbine wheel.
Registered User
Any updates on when that one sitting under your desk is going to be ready???
hmm...when does fall end? website says fall 2008
fidgety in a good way...heck, I'd take a BBKLite and live happily ever after I reckon
too many pages to read
from what i have read do i have this right?
spools as early as a green or sooner and has red or more power?
LOL ... If that were true, no one would ever buy any other turbo unless they were trying to run 8's.Originally Posted by leecavturbo
too many pages to readfrom what i have read do i have this right?
Chad has already said more than once that this will not make as much power as a FP Red on a properly setup car. But it was never designed for that.
LOL ... If that were true, no one would ever buy any other turbo unless they were trying to run 8's.Chad has already said more than once that this will not make as much power as a FP Red on a properly setup car. But it was never designed for that.
you never know in the world of tuning 2 yrs ago who thought 500whp on 93 was capable (don't quote me)Evolving Member
posted aboveOriginally Posted by leecavturbo
Quote:
power under the curve, spool, transient response, and good boost up top..
check
cb
Originally Posted by CBRD
i hate to say it, this turbo wont match a red at higher boost... the red flows 10lbs min more than our turbo... this was designed for exactly what it accomplished today... MEGA pump gas numbers...power under the curve, spool, transient response, and good boost up top..
check
cb
DSMs were making 500whp on pump way longer than 2 years ago.Originally Posted by leecavturbo
The power curve sure looks alot like a Red but from what I've seen form the last 50 pages the aim of this turbo is more of a 50 trim killer or 3071 killer than a 3065/2076/GT35 killer like the FP Red if that makes any sense.
BBK is also designed to give good gains, quick spool and fast-as-lightining response on pump gas, not so much targeted towards the big boost, race fuel drag crowd.
If it spools quicker than a Green and pulls strong right up to the top, with a decent increase over the stock IX turbo over the entire rev range on pump gas then what I'm after and that's why I'm stalking this thread.
SO far, I think this puppy delivers and we've only seen half the turbo so far
Hope it comes out soon...I need a turbo pretty quick!
Quote:
i did say don't quote me Originally Posted by Steve93Talon
This turbo is going to be equivalent to a Green. If I remember correctly I think Chad said it will flow 38lb/min. Isnt a Green right around that? Remember, that 427whp Charlie made was with a stage 3 head, aggresive cams, a sheet metal intake mani, etc. And if you look at my sig, the conditions that day were OPTIMAL for peak numbers. I bet on a bolt-ons only car this thing would make around 400whp which is about the same as a Green. I think Caleb said his IX made 376whp on the full BBK with stock IX cams, stock uicp, and some other things. The area under the curve is what might be interesting to see, not peak numbers as it is said to be a bit more responsive than the Green. So that should give a clue as to what this think will do for us bolt-on daily driver kinda guys.
Quote:
Agreed, the flat TQ "curve" is what impresses me the most. That with the quick spool and nice gains up top make this the ultimate street turbo in my opinion.
SQ
Quote:
You're misremembering. That's less than stockOriginally Posted by TURBevO8
. Add 10+ to that.Quote:
SQ
The built head certainly lends to the broadness of the torque curve. Originally Posted by Nuked
Agreed, the flat TQ "curve" is what impresses me the most. That with the quick spool and nice gains up top make this the ultimate street turbo in my opinion.SQ
I have mild head work and revolvers (among other stuff) and am very curious to see what my combo produces.
