HTA3076R vs FP3065
Old May 15, 2008 | 02:19 PM
AcePitcher11's Avatar
HTA3076R vs FP3065
Well I always see threads comparing these turbos to the HTA35R but what about comparing these two? What's the spool up like for these two?
What power do they make on pump?
What power do they make on meth or race gas?
All this based on dynojet numbers.
This is also being based on stock block, head, etc. With all bolt ons.
I'm debating between these two setups but I'm not sure which would be better.
Old May 15, 2008 | 02:45 PM
PVD04's Avatar
I have the 3065 and after looking at the dyno plots from the HTA 35R and HTA 3076R I would say pick one of the other two. The 3076 will spool a bit sooner but be down on power, the 35R will spool a bit later but make a ton more power. The 3065 probably won't make much more power than the 3076 but will spool noticeably later. If you need early spool, get the HTA 3076R. If spool is not as important, get the HTA 35R.
-Paul
Old May 15, 2008 | 03:25 PM
-Paul
I'm shooting for mid 400s on pump and close to 500 on race gas. The HTA35R is a sick turbo but I don't have the money to build the head to rev high enough to get the full potential of the turbo and I'm not looking to build the block anytime soon.
Old May 15, 2008 | 03:27 PM
housedj's Avatar
go with whichever turbo has a ported shroud
Old May 15, 2008 | 03:29 PM
4DR's Avatar
4DR
based on that ^^^. HTA 3076!!
Both turbos will get you low 400s on pump. 500 on race gas is easy for a 35R.
Old May 15, 2008 | 08:08 PM
But does the 3065 make better power than the 3076 or what is it about the 3076 that would make me choose it over the 3065? Keep the advice coming!
Old May 15, 2008 | 08:12 PM
fugiwara's Avatar
HTA3076, when does it hit full boost?
Old May 15, 2008 | 08:14 PM
Eric06's Avatar
Call Buschur Racing.
Old May 16, 2008 | 08:30 AM
So if I did go with the 3065 and mostly was on pump but ran race gas at the track what size injecters will I need 880s? Also what kind of traps are people getting with the 3065 on pump?
Old May 16, 2008 | 08:45 AM
evoPirate's Avatar
You could come close to, if not actually hit, 500 with the 3065 on race gas. Jarrod @ buschur hit that on c16 I belive with stock block and head and not too much in the way of parts. I'd imagine you'll come close to 500 on race gas with the 3076 as well. If that's like your max goal on c16 for the track, get the 30 series and keep some spool for the street!
Old May 16, 2008 | 09:04 AM
deadbeatrec's Avatar
I have the ATP 3076r and made 504whp 456tq with 29psi with a throttle body seal leak. im very happy with mine.
Old May 16, 2008 | 09:45 AM
How much faster does the hta3076r spool compared to the 3065? And what were your numbers with you street tune on pump?
Old May 16, 2008 | 09:53 AM
CBRD's Avatar
i am posting some charts, with hta, 3065, etc.. in another thread, it will be up shortly
cb
Old May 16, 2008 | 01:27 PM
cb
Sweet...how long till you will have those graphs out? Im planning on buying soon but I would like to see you comparisons.
Old May 17, 2008 | 04:45 PM
bump
romogst
18
Feb 26, 2016 11:37 AM
David Buschur
Sep 6, 2015 09:27 PM
mrfred
Dec 31, 2014 08:27 PM
dambikeracer
32
Nov 19, 2010 09:20 AM
mmp52
97
Dec 17, 2007 01:23 PM
