35r Dissappointment then Happiness
Old May 16, 2008 | 10:53 PM
midnightsuns's Avatar
Well installed my 35r kit with Meth injection and was highly upset when I went to the dyno and the most we could pull out of it was 24 psi and 300 hp, figured it was just the wastegate spring being maxed out. I then pulled the plugs later on that day which were NGK BPR8ES's and had been run since around 12,000 miles. (car is now at 52000 I know I know, retarded) Well I'm driving down the road the next day and decide to romp on it, holy crap, all 4 wheels spin for a second around the 5500 rpm range and my profec b is saying that boost peaked out at 32 psi. Apparently the plugs weren't burning any fuel because any attempts to boost past 15psi results in the car starting to lean out. Guess it's time to retune with working plugs and see what this bad boy cranks out.
Old May 17, 2008 | 06:41 AM
evoPirate's Avatar
be happy its something as simple as getting new plugs!
Old May 17, 2008 | 11:15 AM
I know, we were baffled, he just looked at me strange after the first pull. It should def be above the 400 plateau.
Old May 17, 2008 | 12:48 PM
Import Junky's Avatar
I would have thought it would start breaking up. I know when my plugs went bad.....it was after a nice pull to 162mph ***on the track***...hehehehe. I decided to go get some gas and when I got onto the on ramp I rolled into the throttle and it fell on it's face. Did your car not act like this on the dyno?
Old May 17, 2008 | 06:32 PM
4DR's Avatar
4DR
Your tuner should have asked you about your plugs! Plugs have a huge impact on the performance of turbocharged engines.
Old May 17, 2008 | 06:41 PM
High_PSI's Avatar
WOW an RNR kit.........
Old May 17, 2008 | 10:00 PM
it's actually just an RNR turbo manifold, the rest is pretty much custom. yeah no break up but after I changed the plugs the readings shot up into the lean area from 15psi on, sooooo yeah, made a drastic difference. Oh well now we just gotta add more fuel and crank out the POWA!
Old May 17, 2008 | 10:02 PM
alan678's Avatar
Yo!
Old May 17, 2008 | 10:09 PM
casper980's Avatar
Doh! Change your plugs before they go bad! At least every 15K miles, $60 on spark plugs can save you thousands. If your pushing over 400whp change em more often....IMHO.
Old May 17, 2008 | 11:18 PM
nasty8evo's Avatar
wow! you have to watch the little things like that!
Old May 18, 2008 | 12:24 AM
Well got more dyno time at gotham racing on monday, intially about 2 weeks ago cranked out good power on another dyno but they're notorious for making people happy so going with gotham to make sure the numbers are legit. Just gotta pray now.
Old Jun 3, 2008 | 02:16 AM
Inprogress's Avatar
Any updates on this situation?
Wheatley
17
Jan 13, 2011 10:56 AM
Magnumpsi
Evo X Dyno Results
28
Dec 19, 2010 07:10 AM
bevolucion
Dec 15, 2009 04:55 PM
jslater2306
Mar 3, 2009 03:31 PM
EvoDan2004
16
Jan 29, 2008 02:41 PM
