Spark Tech vs AEM EMS
Old May 29, 2008 | 03:15 PM
CA$H's Avatar
Question Spark Tech vs AEM EMS
I know having both would be the best way to go but if I had to pick one which one and why.
With a tune I'm looking for the best power mod. (I know AEM EMS is more money but IDC)
I'm on stock turbo running meth @30psi (depends what gear you're in sometimes more psi)
Thanks
Old May 29, 2008 | 03:19 PM
EvoDan2004's Avatar
well you can make more power with both. and also the stock ecu is fine as so is the stock ignition. what i would do is get the basic spark tech ignition. the aem cant fix a missfire. and you really dont want to run a .020 or lower plug gap. get the c.o.p. run a .028 to .030 and never worry about an ignition issue for the rest of your life. then get the aem later down the line.
Old May 29, 2008 | 03:35 PM
DG Motors's Avatar
+1
Old May 29, 2008 | 05:41 PM
Ted B's Avatar
If you're successfully using 30 psi on the stock turbo and are not having problems, I'm not sure why you're looking to fix them.
If I were in your position and was itching to spend pursuant toward more power, I would consider a top tier FMIC, cam upgrade, turbo upgrade, tubular manifold, or something else that will enhance airflow. I'd also invest a bit of time in learning how to upgrade, tweak, and tune the factory ECU as best as I could. You may already be doing or have done these things, I don't know.
If it ain't 'broke', don't fix it.
Old May 29, 2008 | 05:57 PM
CA$H's Avatar
Thanks for the kind words. Did I say I'm not having any problems?
On another note: I am itching to to upgrade but, the scratch is limited.
If I had the money to blow I wouldn't be asking lame a$$ questions on car forums to try and save a buck!?
Old May 29, 2008 | 06:30 PM
Ted B's Avatar
You didn't say you were having any problems.
You asked for the 'best power mod'.
I was trying to be helpful to you.
RSGuy
10
Apr 30, 2015 05:43 PM
jansoft_16
AEM EMS
May 8, 2013 09:41 AM
crisdiarata
AEM EMS
May 2, 2013 12:17 PM
shunderwunder
AEM EMS
Jun 14, 2008 07:06 PM
ugotownd
Sep 22, 2004 02:14 PM
