fp red
For me, the upgraded FP actuator forced me to turn down the boost controller to keep mid-range boost in check. The net effect is that I had less boost/tq/hp where the car initially hit "full boost," but then the same peak boost in the middle of the curve. I didn't like it at all for my then pump gas needs.
^^^ +2 here. I had a ported Green with FP HD WGA initially, back when I would only run pump 93
Because of the creep from 23psi to 25.5psi (at wastegate pressure - mbc was all the way down) at like 5500rpm, it caused the car to knock and pull timing, so we swapped it back out for the stock WGA and got back that stock-turbo torque spike that is so fun for the street.
Here is the picture of what you are talking about:
This was back then, creeping up & peaking at 25.1 psi (hump or the creep) and droping to 22.xx at redline.
Then, after tweaks with the EBC, this is what it looks like now, 26 psi peak, 93 pump gas, drops to 23.5 at redline, no creep or hump:
So that creep can be corrected with the E0-1.
Here is how I got it tuned by rpms:
WTB[West]: Wtb FP red
jeremy52048
Jun 16, 2015 10:36 AM
FS[SouthEast]: Fp 25psi wga
slowsrt4:(
Feb 14, 2015 05:20 AM
