fp red
Old Aug 9, 2008 | 01:41 AM
  #91
ninekrevs's Avatar
Originally Posted by kkarim
to the people who are receving the Red's now, did any of you guys get it ported/coated as well? I was told by FP that this might delay it a couple of extra weeks (lord knows how much in FP years).
one month equals 2 FP years. porting shouldn't delay it much because they do that in house, coating is what takes a long time because they have to send it out to someone else to coat it.
Old Aug 9, 2008 | 02:02 AM
  #92
TTP Engineering's Avatar
Originally Posted by ForcedPerformance
I don't remember really. I'm not sure we ever really operated it without a solenoid on the line to up the boost. We have on other smaller variants that would give about 17psi or so with no solenoid.
21-23psi peak on wastegate pressure.
Old Aug 9, 2008 | 02:08 AM
  #93
Results are in.
110octane Sunoco pump gas leaded
Full boost spoolup 3800rpms
33-34 maximum psi with HP actuator and full + MBC
27.5psi @ 8000rpms on HKS 280 280
Final numbers 463.1whp/445tq Mustang Dyno - Evo 8
Overall, I like this turbo and think we could have done without the Green altogether compared to this one. It appears FP put together a good combination this time.
Old Aug 9, 2008 | 02:37 AM
  #94
jouniu's Avatar
Originally Posted by TTP Engineering
Results are in.
Great numbers. How much ignition advance @8000rpm? What size injectors?
Old Aug 9, 2008 | 04:18 AM
  #95
ninekrevs's Avatar
Results are in.
That doesn't sound too impressive since you make close to those numbers with the stock Evo 9 turbo.
Here is a thread where you made 429whp/469wtq on the stock 9 turbo
https://www.evolutionm.net/forums/sh...d.php?t=351292
Here is another thread where you made 431whp/456wtq on the stock 9 turbo
https://www.evolutionm.net/forums/sh...d.php?t=359240
Old Aug 9, 2008 | 05:18 AM
  #96
EVO8LTW's Avatar
TTP, have you posted the dyno graph?
Old Aug 9, 2008 | 06:26 AM
  #97
Shacochis06's Avatar
[QUOTE=ninekrevs;5990481]That doesn't sound too impressive since you make close to those numbers with the stock Evo 9 turbo.QUOTE]
+1 on that but all those other cars are on the magic meth...if this is not on just 93 pump ill be dissapointed
Old Aug 9, 2008 | 06:31 AM
  #98
Hikaru's Avatar
^sunoco 110. Not really impressive for what they have done before.
Old Aug 9, 2008 | 06:34 AM
  #99
Mellon Racing's Avatar
he said in his post 110 octane leaded but still 463awhp is stout for a stock appearing turbo.
Old Aug 9, 2008 | 06:59 AM
  #100
ninekrevs's Avatar
110 Sunoco at 34psi
Old Aug 9, 2008 | 08:28 AM
  #101
gsrboi80's Avatar
Results are in.
Excellent Scott thanks. This is a sick turbo for the price no doubt. However it should put the kabosh on the other thread pitting it vs. a 35r
Old Aug 9, 2008 | 01:07 PM
  #102
BlueDemon's Avatar
Uhhhhhh, both of those numbers were made on a evo 9 with meth and the results he gave ya just now was on a evo 8 with Sunoco 110. We'll see if he can get some more impressive numbers on a evo 9 .
Old Aug 9, 2008 | 02:59 PM
  #103
ninekrevs's Avatar
meth and 110 leaded race gas sound like a even comparison to me. The differences between the Evo 8 and Evo 9 engine at this level of modification shouldn't have that big of an impact on whp.
Old Aug 9, 2008 | 03:06 PM
  #104
gsrboi80's Avatar
+1 agreed
Old Aug 9, 2008 | 03:19 PM
  #105
kkarim's Avatar
Results are in.
3800rpms isn't bad at all.. what gear is that in?
