fp red
Old Aug 6, 2008 | 10:50 AM
  #61
CO_VR4's Avatar
Originally Posted by Mellon
CO_VR4 are you seriously going to try to convince us that 100 octane is pretty much the same as 93 and doesn't allow for more boost or timing? cmon now
No, what I'm "seriously trying" to get you to understand is that 100 octane is NOT race gas (as some have termed it), and was being used in this circumstances (26PSI) to have a better margin against detonation, not to increase power. Anyone who has ever compared their fuel and timing maps between pump and race gas knows that C16 or similar fuels have totally different maps than 100 unleaded or any other gas you get out of the pump... 100 UL may, in some areas, allow for more boost, but it wasn't done here, limited to 26PSI, when the ambient temps are in excess of 100F.
The point is that that, as tested, there is no major difference in performance numbers between 93 and 100 octane at the boost level of 26PSI.
Old Aug 6, 2008 | 10:53 AM
  #62
RazorLab's Avatar
Boost is not everything, if it was, everyone with a MBC would be a tuner.
Saying there is no performance advantage between using 93 and 100 octane is ignorant.
The "as tested" disclaimer obviously protects your statement a little bit. I still think it's really stupid to run 100 octane and run the same timing, AFR and boost as 93, but if you like spending more for the same performance, go ahead.
Old Aug 6, 2008 | 11:07 AM
  #63
CO_VR4's Avatar
Originally Posted by razorlab
No I get that part. I pump 100 octane into my car every week from a pump here in Kalifornia. I get that part, but I never call it "pump gas". I can also pump 110 octane if I wanted.
You can throw up a huge batman search light into the sky and say it's able to be pumped from a pump at a gas station which makes it pump gas. It still won't change the fact that people on this board understand that "pump" means 87-93 octane.
This whole laughable issue is getting pretty retarded. You can run leaner AFR and more timing on 100 compared to 93 octane, you can also run more boost if you want. So let's all give each other a group hug and just say 100 octane is a whole 7 points more octane then the next "pump gas". It might not be race gas in the leaded rocket fuel sense, but it sure isn't pump gas.
I can count just like most of the EvoM readers. What is "pump gas" in some parts of the country is obviously different than others. We continue to swerve off topic, though, because you continue to try to make an issue out of the use of 100UL fuel while you ignore the fact that the boost in the test you complain about was limited to 26PSI, thus limiting any significant advantage in power that might in other circumstances be a legitimate topic of discussion.
You are welcome to your own opinion as to what is "stupid". Personally, I think that using the extra safety margin obtained by upping the octane of your fuel and preventing detonation in a non-knock-equipped car by spending an extra $1.xx per gallon for your fuel is pretty smart.
Old Aug 6, 2008 | 11:15 AM
  #64
RazorLab's Avatar
Not ignoring it at all, you are ignoring that boost isn't everything.
93 limited to 26psi
vs
100 limited to 26psi
I would place my bets on #2 every single time that it will make more power.
I'm done with this simply laughable discussion we are having, as at this point, we aren't even talking about the red anymore.
Old Aug 6, 2008 | 12:19 PM
  #65
LilRico's Avatar
Originally Posted by Mike@AwdMotorsports
let me know where i can find a DBB 45r for 1800.00.. ill buy them all. LOL
Its not just changing wheels.. Its the work that goes into development, labor to build and machine the turbo, the billet wheel is not cheap also.. alot of factors play a role..
Well... I guess I need to know a little more into what goes into making the turbo and I should of said 40R to some 42R's .....
Old Aug 6, 2008 | 12:39 PM
  #66
evolved83's Avatar
So how many of these are you going to be able to produce within the next few months?
Old Aug 6, 2008 | 01:14 PM
  #67
ForcedPerformance's Avatar
Count me in on the group hug, but nobody better grab my a$$!
I think we will build a couple hundred over the next few months, lord willing and the creek dont rise, as they say here in Texas.
Old Aug 6, 2008 | 01:29 PM
  #68
SpoolnupTuning's Avatar
93 limited to 26psi
vs
razor i have to agree on this one!! more octane means more timing, we all should know what that means
Old Aug 6, 2008 | 02:11 PM
  #69
9sec9's Avatar
I'm certain that I'm wrong, but 93 octane has a faster flame front than 100 octane. Because of that, 93 doesn't NEED the timing that 100 octane uses. Remember, the maximum force on the piston should STILL occur at the same point in piston travel. Now, introduce more HEAT (such as Texas and Oklahoma are currently experiencing) into the intake vs say 75-80 degrees on the West Coast, or even 90 degrees, and typically, in OK, TX, we need to PULL timing to compensate for the heat. IF the 100 octane allows for more timing in MOST parts of the country, that is tremendously negated by the heat we experience in OUR part of the country. Now, where am I wrong. Sorry for the OT Robert, but not everyone understands 105-110 degree temps like you and I experience in our part of the world. I would imagine that what we run on 100 here in the summer heat is pretty close to what others in cooler parts of the country run on 93. Even 1-2 degrees more would not result in much power difference, maybe 5-10 whp.
Old Aug 7, 2008 | 12:47 AM
  #70
brazilbro's Avatar
Originally Posted by PsychDr. HN$
I would say that you def need a FMIC. Try the ETS 3.5. you prolly couldve went with the single pump with 1200cc. Are you going to do anything with the exhaust manifold before the tune? im subscribed because our set-ups will be very similar. Good Luck and subscribed
I have the XS POWER exhaust mani, as far as the pump i havnt ordered it yet.. i'm still trying to decide if i really need the double or not , and if i should get the 1000's or the 1200's injectors=(
Old Aug 7, 2008 | 05:17 AM
  #71
sparky's Avatar
Robert: Can the Red be fitted with a 9.8 HS?
Old Aug 7, 2008 | 12:39 PM
  #72
No reason why you couldn't other than you may spool it up fast enough to have a surge problem perhaps?
Old Aug 7, 2008 | 01:20 PM
  #73
Mellon Racing's Avatar
wouldn't a 9.8 defeat the purpose of the turbo....that's like buying a 35R and putting a tiny exhaust on it.
Old Aug 7, 2008 | 01:23 PM
  #74
Robert i was wondering how much boost you are getting on wastegate pressure?? do you think that 23 is too much for the fp hp actuator?
Old Aug 7, 2008 | 01:27 PM
  #75
AWD Motorsports's Avatar
Finally got to have a RED in my hands.. Very sweet turbo.. Customer snagged and i forgot to take pictures of it before he left.. We have 3 more on hand though if anyone is interested.. They wont stay long i am sure..
