o2 sensor question
o2 sensor question
My engine service light came on today. I took it to advanced auto parts and they did their plug-in device to tell me what was wrong. They said it was my o2 sensor. I was just wondering do i have to replace this immidiately? My work sschedule is really tight right now. I'm guessing that it would be alright to drive around with it for a week until i can get it fixed but I don't really know much about that.
oh, i did just get an exhaust, high flow-cat, boost controller, fuel pump and a custom tune. So i think this is the reason. Thanks for reading and to the people that reply
that being said, most tuners don't add that feature to the ecu.
i also have some other nifty things that came with that including no lift to shift, valet mode, and a couple others.
to the OP, depending on what code it is, i wouldn't be too worried about it. i am assuming it is a p0420. Catalyst efficiency below threshold code.
if so, i wouldn't give it a second thought. it will eventually reset itself. unless you have an inspection coming up, or get tired or looking at it. (it's good to reset it though just in case another should happen)
no need to contact the tuner... he'll tell you the same thing we are.
it's because of the high flow cat. you need to add the mechanical o2 fix/spark plug non foulers/whatever the kids are calling it these days.
it will screw into your rear o2 sensor and your CEL will be cleared. takes about 5 seconds to install and you're good to go. i, like everyone else had to rig one up once i got rid of my cat.
minimkiv
Evo X How Tos / Installations
Jun 11, 2009 05:15 PM
minimkiv
17
May 4, 2009 11:10 PM
