Running Meth? Safe or Not
Old Aug 8, 2008 | 06:14 PM
  #91
Evoryder's Avatar
Originally Posted by lemmonhead
if you look at data on WB they respond very fast, like 0.1 seconds. No way is 300-400RPM a lag from a WB. NO way is a fail safe system going to react faster than a WB. my point is proven. if 300-40RPM is enough for people to feel and complain about in throttle hang. Definetly engine damage can occur within 300RPM if the fuel is running to lean. My point is Proven.
Ignorance is bliss. The masses hate on meth just because of hearsay. How many people have blown motors from bad tunes and just happened to have a meth kit, quite a few times they test the meth and it was running fine. Huge misconception with meth. You must know what you are doing, understanding the do's and don't s will result in a wonderful system with GREAT results.
I have been using methanol for about 6 years. I'm addicted. I rather not spend 3-4grand on a new motor so invested in failsafes.
I am running100% meth, Zeitronix WB,EGT,BOOST, with Audible, Visual trigger. Incorporated the mac valve to cut boost once the zeitronix detects fuel/egt+boost settings reached which are past a threshold. To further complement the zeitronix is the Aquamist DDS3 flow sensor. Lets me know when fluid in tank is low and makes sure the pump is flowing enough meth. If the flow is below a set threshold, and/or if water is low it will trigger the boost cut and thanks to JackofTrades & Tephra's match switching I will dump more fuel with my richer secondary map.
Here is a thread I made that shows my failsafe reaction time:
https://www.evolutionm.net/forums/sh...lsafe+reaction
Don't hate on meth until you get to know her.
Old Aug 8, 2008 | 06:35 PM
  #92
EvoJoeIX's Avatar
Originally Posted by Evoryder
Ignorance is bliss. The masses hate on meth just because of heresay. How many people have blown motors from bad tunes and just happened to have a meth kit, quite a few times they test the meth and it was running fine. Huge misconeption with meth. You must know what you are doing and was you understand the rules and do's and don'ts you can have a wonderful system with GREAT results.
Well said bro
like ive been saying its all about having a good tune and preparing for what can happen if something fails
meth is amazing, the people who are to afraid to try it just hate on it
Old Aug 8, 2008 | 07:13 PM
  #93
C6C6CH3vo's Avatar
Over 40,000 miles of methanol use, car is approaching 70,000 miles.
So long as the car has no liver and drinks responsibly there's no problem. Had my share of close calls early on though - hoses popping off, running tank dry, and several other stupid boost spiking experiments.
Old Aug 8, 2008 | 07:24 PM
  #94
JeffMas1587's Avatar
im running 100% meth and have had 0 problems with it. the car is my dd and im not easy on it by any means. kevinD tune and install ftw
Old Aug 8, 2008 | 07:37 PM
  #95
ronitlancer's Avatar
Lots of good info in here. I'd like some more Tuner responses, they probably know best... they dont just have horror stories and success stories, they put on 200 meth kits, and they know the percentage of safe or not....
Old Aug 8, 2008 | 08:08 PM
  #96
Dragking2189's Avatar
look meth it's the **** but sometimes can be dangerous becasue if the failsafe fails once BOOOOMMMMMMM, blown engine but just go for it what are the odds
Old Aug 8, 2008 | 10:07 PM
  #97
Evoryder's Avatar
odds of a fuel pump clogging, what happens then? or fuel line clog? or fpr hose gets disconnected for prolonged time. They all happen, so do bad meth kit installs with no failsafes. I've seen meth kits installed without soldering. I'll leave it at that.
EvoLucio
Mar 9, 2016 09:42 PM
tonyboy
Feb 28, 2010 05:08 PM
alex750803
Sep 24, 2009 10:19 PM
Celica2EVO
13
Jan 18, 2008 10:17 AM
DS-03evo
32
Feb 17, 2007 09:09 PM
