FP EVORed 470whp on 26psi with 100oct UL fuel
antilag_200 damn robert, I thought I was the only one here using a PMAS meter.... ( this is warren, nick Wolgamotts old roomie )
U guys should switch to their blow through design, it works quite well
you can just add the saddle to the pipe
kind of like this ( you can see the meter right by the TB )
and I believe nick can get them to you in a 2.5 inch saddle.
anyway your turbos are awesome, time for me to send a little something your way for HTA treatment
I apologize for my earlier bashing of the fp white, seeing how close your car is to the usual boltons, meaning no retardedly expensive diminishing gains parts (sans the motec), to trap 124 in the middle of summer texas heat is damned impressive, even if it is on 100ul.
Wow.
Wow.
I am responsible for that engine bay, but I am not going to ***** roberts thread, I just wanted to show him the saddle. I really think he would benefit from it, but I am just a lowly guy on the totem pole, robert definitely knows what he is doing
I only drive the car on 100 octane fuel. I have not had 93 in the tank for a loooong time. The main reason is that the Motec M800 does not have a knock control feature and I cannot risk hurting my motor during testing. If the motor breaks during testing then you HAVE TO START ALL OVER, which pretty much sucks. So I spend $5.99 a gallon on the 100 and dont sweat being on the "edge" counting on the knock retard to bail me out when it comes to the timing map - that way I dont hurt anything. It is a matter of finishing without failure vs
failing and not finishing the test battery at hand.
That is what being a baller is.
