FP Red......565awhp/557awtq on E 85!!!!!!!!!!!!!
Old Aug 10, 2008 | 03:37 PM
  #61
big block ix's Avatar
2.3 L red set-up FTW!!
4 weeks until I get MY red on my car
I will post pump gas dyno sheets
Made a lot of tq on pump 420tq and i'm expecting more out of my Red... Or at least a wider powerband to play with...
Old Aug 10, 2008 | 03:50 PM
  #62
Warrtalon's Avatar
May not see a big jump in peak torque, but the torque curve itself should get higher across the board as it is more efficient as RPMs rise than the Green, which will translate into much higher WHP numbers. Not sure how drastic on pump gas, though.
Old Aug 10, 2008 | 04:00 PM
  #63
RazorLab's Avatar
So far the Red's in the general public are looking promising.
I would be interested to see what the spool is like with a 25-26psi peak, as we all know it will hit 20psi sooner if it's shooting for the moon of 30psi.
Old Aug 10, 2008 | 04:21 PM
  #64
TopLevelPerformance's Avatar
Dam near impressive numbers, the Red is plain sick
Old Aug 10, 2008 | 07:41 PM
  #65
hokiruu's Avatar
Green on E85 was impressive torque, but with how quickly they fell off, and seeing how E85 is "the torque fuel", a 2.3 is the spool/tq. engine, it just makes sense on a Red.
Frank, this just makes me want to keep and use the hardware we talked about . Every time I look at the curves, I am still impressed with how brutal the power delivery is.
Old Aug 10, 2008 | 07:46 PM
  #66
92gsxbaltimore's Avatar
Turbo looks impressive.
On a side note: According to the local news, in all of MD there are only 5 stations that carry E85, and I have never seen one myself.
Old Aug 10, 2008 | 09:14 PM
  #67
sparky's Avatar
3 peeps have now claimed 30ish PSI by 3800 RPM for the Red(Trent, Scott of TTP,and one other). This is pretty incredible spool for a turbo that can deliver 3076-like power.
I hear what you are saying though....When peakboost is octane limited to 26 PSI, will the Red's rate of spool be negatively impacted to any considerable extent.
Old Aug 10, 2008 | 09:24 PM
  #68
TwStDeVo's Avatar
definitely nice to see this turbo on a 2.3 build, top end dont seem too bad, now my question is how would it compare to a hta35r? comparing two cars with the exact same build and fuel. would the faster spool overcome the better topend of the 35r? finally, it would really be nice to see a graph overlay of a hta35r car with similar mods and boost and this turbo.
Old Aug 10, 2008 | 10:16 PM
  #69
03evo8gsr's Avatar
i should be getn my sometime end of ths week with my open dump o2, ill be runnin 91oct+100% meth. im currently at 389whp and 378tq all basic bolt ons and evo 9 turbo and 2727 cams. im very curious of how the new setup is goin to do.
Old Aug 11, 2008 | 12:43 AM
  #70
RazorLab's Avatar
Yea for sure, I am very impressed. I am also very curious of what the spool will be like at "normal" boost levels. I might be impressed again.
Old Aug 11, 2008 | 08:42 AM
  #71
PPI's Avatar
PPI
Nice Frank, looking forward to the ride!
Old Aug 11, 2008 | 08:45 AM
  #72
Mellon Racing's Avatar
If you're driving an HTA 35R car and experiencing lag you're doing something wrong...brake boost and or downshift
Old Aug 11, 2008 | 08:49 AM
  #73
TTP Engineering's Avatar
Originally Posted by blowoffsilver
on a gm maf?
The first question that should be asked is, "compared to what"?
Old Aug 11, 2008 | 08:58 AM
  #74
scorke's Avatar
No.
The HTA 35r, 35R, 30R all offer a considerable amount of lag compared to a stock turbo.
There is no way around the increased spool times and boost response associated with going with a bigger turbo, some might be better than others but none compare to a stock framed smaller turbo.
Scorke
Old Aug 11, 2008 | 09:02 AM
  #75
ok, pull up beside me with a 16g, green/red/blue/white whatever, 30r and see if that quicker spool makes any difference.
I'll brake boost and be at 30psi and when it's time to go it'll be all over but the cryin and if you're going from a dig I launch at 7000rpm on the 2step at 15psi, there's no respool time on shifts either.
