cam gear settings
Old Dec 16, 2013 | 05:52 PM
  #211
NousDefions's Avatar
They are standard length. I didnt opt for an LR as its more a daily driven street terror than anything else
Old Dec 16, 2013 | 06:07 PM
  #212
Ted B's Avatar
For that cam set and turbo, for strong street pop, I would go +1/+1. If you don't mind a choppier idle, +2/+1.
Old Dec 16, 2013 | 06:12 PM
  #213
I'll give that a go. Thanks, your advice is greatly appreciated
Old Dec 19, 2013 | 10:00 AM
  #214
Kronik's Avatar
As always the best cam timing compromise varies according to what the engine is intended to do. When it comes to stroker engines that shorten the rod/stroke ratio, they slow movement of the piston around BDC, which means the intake cam would need to be retarded by a degree or two to equal a zero setting with a 2.0. It also means stroker engines tolerate a bit more effective duration on the intake. This being said, for a GSC S2 with your setup on the street, I'd try 0/-1 or maybe 0/-2.
Ted, just so I understand correctly for my build. In order to get this 2.4 at 0 degrees I had to set the cams to -3 / -3. So are you suggesting putting the cams at -3 / -4 (or -3 / -5) ... or actually setting them at 0 / -1 (0 / -2)??
Reason I ask -- I did get this car dyno tuned. I was quite disappointed to be honest. I know I need to change the 02 housing (still stock) but the tuner did not like the cams. He suggested getting Kelfords (272). I really can't see the cam of choice being the issue. I'd believe the 02 housing over anything. But I want to make sure I have the cam gears tweaked correctly.
I'll also add this is a 2.4 build, stock length rods and stroke. The car only put down (on a Mustang Dyno) 370 hp and 400 tq (but only at 22 lbs of boost with the bbk-b turbo). We didn't crank the boost since the restriction in the flow didn't change top end power. No sense and stressing the block. So waiting for the o2 housing (for xmas I hope )
Old Dec 19, 2013 | 10:47 AM
  #215
Biggy VIII's Avatar
You said "retard"+"intake", but then mentioned 0/-1 0/-2 cam gear settings which mean retarded exhaust...
Is that a typo or am I missing something??
Old Dec 19, 2013 | 11:09 AM
  #216
Ted B's Avatar
Originally Posted by Biggy VIII
You said "retard"+"intake", but then said 0/-1 0/-2 which means retarded exhaust...
I just didn't explain it well enough. If he had a GSC or Kelford cam with a 107 deg intake LC, I would have suggesting retarding the intake, but the HKS cam is at a 110 deg LC, which about right for his 1.5 R/S ratio setup.
I'm suggesting actually setting them a 0/-1 or 0/-2. That will improve midrange and spool. If it attenuates peak power, you can try retarding everything by 1 or 2 degrees from that point and test again.
At -3/-3, spool is going to be soft and late, although it may make a little more peak power.
I don't like the Kelford 272 or similar shorter duration cams for large displacement 4G63s - not enough valve timing, and a tendency to create knock issues. The larger engines do better with longer duration cams. You may run into this situation with these HKS cams, but I don't have enough real world info about them to be certain at this point. I recommend fitting a larger O2 housing first, before looking at different cams. And if it comes to that a GSC S2 or Kelford 280 is a better bet.
Old Dec 19, 2013 | 12:17 PM
  #217
Kronik's Avatar
Yes, my thoughts on the 02 housing. I've asked Santa for an Invidia 02 housing for xmas lol
You see -- I keep seeing so much conflicting information on where to set the cam gears with this type of build. Everything I found, up until now, said you needed them at -3 / -3 to be "in the ball park of being in time. So I won't have any issues at 0 / -1?? The engine will still be in time and spool quicker? And your comment above made me think you may have thought I have HKS cams. i do not -- I have GSC S2s already in the car. So is the advice on timing still the same??
You described the way the car builds boost exactly to a T. It is soft and comes on rather late ...but once it does hit boost it's fun! So just a small change and I shouldn't have better spool and midrange??!! That's what I wanted with this 2.4. It has tons of torque (even off boost) but it seems flat until about 5k which was odd to me.
Old Dec 19, 2013 | 02:58 PM
  #218
Ted B's Avatar
Ok, I was thinking you had HKS cams, probably because I've been giving a lot of cam timing advice and confused you with another setup. Sorry about that. In your case, with GSC S2 and what you want out of it, I would try -1/-2 and see what that does for you. That will spool a little quicker and give it more pop in the midrange.
Old Feb 24, 2014 | 10:19 AM
  #219
BlackEvo_5's Avatar
love this post
Old Feb 24, 2014 | 11:52 AM
  #220
Terror Rising's Avatar
Ted,
Currently building up my car for auto-x. I will be running an HTA71 with BC272s. I know that you say you can't recommend cam gear settings for them because they're not as published. I am planning on degreeing them to find lobe centerline so I don't necessarily care about published specs, and at that point the numbers on the cam gears are only reference points. Once I've established true centerline what is your recommendation for optimum low/mid spool without a huge sacrifice on top end?
Old Feb 27, 2014 | 07:49 AM
  #221
URNVS's Avatar
First of all let me say thanks to Ted for all of the great information thats been shared so far in the thread!
What would you suggest as a starting point for my setup?
Cosworth 272's
GT35r
Weekend street use and occasional trips to the strip.
Old Feb 27, 2014 | 08:18 PM
  #222
swalltr207jg's Avatar
Ted, suggestions for a stock bottom end 2l
No mivec
Gsc s2's
Slight head work, gsc beehive springs
gt3071r turbo
Ams f1i intake and ams exhaust manny
Old Feb 27, 2014 | 11:12 PM
  #223
mr evo7's Avatar
2.3 with a PTE 6262 0.82.
Head ported with +1mm inlet valves. Gsc s2 cams and fidanza cam gears.
Car is a little laggy. What is best setting to help the spool but still maintain top end
Old Feb 28, 2014 | 12:30 AM
  #224
Ted B's Avatar
In both cases I recommend leaving the GSC S2's at 0/0. These cams are already timed to give best possible spool without running into issues.
In the case of the GT 3071R, that turbo spools slowly for its power potential, so it needs all the help it can get.
As for the 2.3 with PTE 6262, ordinarily, I'd recommend a couple of degrees of retard to compensate for the different piston position of the 2.3, but with an open .82 AR T3 housing, it's going to need all the spool help it can get.
Old Feb 28, 2014 | 04:00 AM
  #225
mr evo7's Avatar
So both intake and exhaust cam should be retarded
