Idle???????
Old Aug 17, 2008 | 07:57 AM
Slava's Avatar
Idle???????
I got my car started this week after engine rebuild. And it idles very high above 1500rpm with AEM EMS. If i try to reduce Idle% vs Target table (it controls IACV (aka stepper motor)) the car just dieing under 1500rpm. I tried to put stock ecu back and almost same thing happens but it idles around 1200rpm.
I need to know is it normal that it idles that high for my modes.
I have 2.4 bottom: JE pistons 8.5CR , eagle rods.
Head: HKS 280, supertech double springs, all 1mm oversized valves, ported to remove factory casting imperfections nothing major.
I have also tilton twin ceramic clutch wich is lighter than stock.
Also have AMS VSR mani with 65mm TB on it.
Let me know if you need any more info.
Old Aug 17, 2008 | 12:10 PM
Slava's Avatar
bump for answer somebody should have similar modes
Old Aug 17, 2008 | 11:02 PM
Slava's Avatar
bump
Old Aug 18, 2008 | 03:04 AM
sparky's Avatar
You might get better response to your questions over on the Evo Engine Management/Tuning forums. More specifically, there is an AEM EMS subforum
Old Aug 18, 2008 | 05:12 AM
Slava's Avatar
What i want to know, if with my modes my car supposed to idle 1500rpm or it is problem with my engine management. And i tried stock ECU and got almost same result. I just need to get opinion from somebody who has big cams, oversized valves, and light clutch!!
Thanks.
Old Aug 18, 2008 | 05:34 AM
PVD04's Avatar
It is not normal for the car to idle that high once warmed up. You should be able to get the idle down as low as 900 RPM, although it will be very lopey that low. Your issues are most likely tuning related.
Old Aug 18, 2008 | 06:03 AM
Slava's Avatar
Thanks that is what i want to know. I will be going for EMS tuning this week so i hope they will be able to fix it.
Any other thoughts from guys with big cams ??
Old Aug 18, 2008 | 06:51 AM
gsrboi80's Avatar
Check the throttle cable adjustment slide bracket behind the Valve Cover. Too tight and it will hold the plate open hence high idle
Old Aug 18, 2008 | 02:02 PM
Slava's Avatar
It is not a cable. I checked it.
Old Aug 18, 2008 | 02:18 PM
denver's Avatar
Check to make sure the timing belt is in time, I rebuilt an engine on a 1G DSM once, and I was 3 teeth off on the T-belt, it idled very high. I dont think this is the case for you, but its worth checking...
Old Aug 18, 2008 | 02:23 PM
Smike's Avatar
Try adjusting you idler screw. On the top of the TB there is a phillips screw. It controls the idle via the IAC.
Old Aug 18, 2008 | 05:46 PM
Slava's Avatar
Checked timing belt and everything is good. Due to higher block i had to retard the cams 3.75 degrees to get them to "factory" position so it should not be a problem.
Old Aug 18, 2008 | 05:52 PM
Slava's Avatar
Tried that. The problem is if i cut air, either by idle screw or by tuning IAC motor the car dies. It is running at 1500 if i try to lower it just wont idle, afr is about 14.7 and it follows perfectly AFR target table. I tried make idle reacher about 13-12 same problem. Will go to tune my AMS soon hopefully they can find what is the problem.
Old Aug 27, 2008 | 06:37 AM
Slava's Avatar
So i went for EMS tuning and the guy who tuned my car tried to play with idle he made it really lean about 16-17 and it is atable now at about 1300rpm is it still high or that is the way it should be??
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
jackfrog
38
May 24, 2015 05:15 PM
dsevo
Feb 22, 2012 10:08 AM
nothere
Feb 10, 2010 06:25 PM
Clipse3GT
Oct 15, 2009 09:16 PM
